So what's the easiest way to square off this pipe?
   / So what's the easiest way to square off this pipe? #42
Oh man,
You guys let the big secret out.
THANKS JOSH for letting the cat out of the bag.
And here I thought I was going to get a new forge.
   / So what's the easiest way to square off this pipe? #44
Take it into a zero-G environment. Then install a gyroscope in it to hold it steady. Now set a cutting laser in orbit around it, using radar range-finding to confirm that the laser's orbit is perfectly aligned with the axis of the cylinder. This will occur when the laser's orbit is perfectly circular (its orbital velocity will be constant) and the laser's distance from the surface of the cylinder is constant. Use monopropellant thrusters to slide the cylinder up or down along its axis so that the laser will cut in the right place. The thrusters must be perfectly symmetrical with each other, and centered on the cylinder's center of mass. Re-confirm that the laser's orbit is still perfectly aligned. Finally, activate the laser to commence cutting. The force of the photons coming out of the laser will cause its orbit to change slightly, but this should be within tolerances for the project and does not need to be compensated for.
YOU'RE WELCOME.
Now there is a simple solution, should workout real well. Just wondering about re-entry.
I bet that roller has been used so much by now that it needs new bushing or bearings. :laughing:
We still working on this???
Haven't even started on it yet. Discovered a water leak problem at my other house that is a higher priority. :(
American G-Model Pump Jack (A56438)
American G-Model...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
Adams 5T Pull-Type Fertilizer Spreader (A56438)
Adams 5T Pull-Type...
KBH Tank Trailer (A56438)
KBH Tank Trailer...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
