So what's the easiest way to square off this pipe?
   / So what's the easiest way to square off this pipe? #42
Oh man,
You guys let the big secret out.
THANKS JOSH for letting the cat out of the bag.
And here I thought I was going to get a new forge.
   / So what's the easiest way to square off this pipe? #44
Take it into a zero-G environment. Then install a gyroscope in it to hold it steady. Now set a cutting laser in orbit around it, using radar range-finding to confirm that the laser's orbit is perfectly aligned with the axis of the cylinder. This will occur when the laser's orbit is perfectly circular (its orbital velocity will be constant) and the laser's distance from the surface of the cylinder is constant. Use monopropellant thrusters to slide the cylinder up or down along its axis so that the laser will cut in the right place. The thrusters must be perfectly symmetrical with each other, and centered on the cylinder's center of mass. Re-confirm that the laser's orbit is still perfectly aligned. Finally, activate the laser to commence cutting. The force of the photons coming out of the laser will cause its orbit to change slightly, but this should be within tolerances for the project and does not need to be compensated for.
YOU'RE WELCOME.
Now there is a simple solution, should workout real well. Just wondering about re-entry.
I bet that roller has been used so much by now that it needs new bushing or bearings. :laughing:
We still working on this???
Haven't even started on it yet. Discovered a water leak problem at my other house that is a higher priority. :(
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
2020 DRAGON ESP...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
