Solder in a stripped zerk???
   / Solder in a stripped zerk???
I got several like that on my backhoe. Only difference was a large nut was used for protection.
Hola Egon, yeah there was a big nut on it before for protection but I cut it off to be able to fix it. that square tube is dinky but better than nothing.
Thanks 2458n!
His problem is not that he lives in Costa Rica, his problem is that he has been given a lot of good ideas and rejects them all. Costa Rica is served with delivery service and anything we can buy, he can buy, too. It may take longer to deliver, though. Additionally, the locals have been getting around these issues forever and there is probably a local guy who can fix it "good enough" for a reasonable charge. Or try bubble gum.
You didn't like the welding the nut on fix? Seems solid to me.
   / Solder in a stripped zerk??? #54
Me to. Drive in zerk would be second choice.
Only to add, if needed, take a 1/16" welding rod and gently tack weld the drive in zerk so it wont pop out.
   / Solder in a stripped zerk??? #55
Thanks 2458n!
Mine didn't have protection. I tried the JB weld thing but that didn't work. A local shop & welder did work!
2006 Ford Econoline Wagon Van, VIN # 1FBSS31L26DA35612 (A57453)
2006 Ford...
2023 Kubota SVL 75-2 Skid Steer (A57453)
2023 Kubota SVL...
4ft Pallet Forks (A57454)
4ft Pallet Forks...
Forklift (A59228)
Forklift (A59228)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
