solid finish mower tires
/ solid finish mower tires #11
I have always run pneumatic tires but never the issues that you guys are talking about. I would think the pneumatics would bounce less and give you a smoother cut.
On the other side I do not have Carlisle tires. I had Carlisles on my mower for the drive and tail wheel but when they needed replaced again because they would not hold air due to extremely quick dry rot I changed brands. haven't had the issue since. I think the issue may just be Carlisle tires.
/ solid finish mower tires #12
We have used TractorPartsCentral.com which had wheel kits with bearings that we used. I think ours were made in Italy, but that is where a lot of finish mowers come from. We later found a still cheaper price on Amazon.
/ solid finish mower tires #13
Thanks Gunny, I have four on the way !
I've been using these from Northern, $20 each right now, but I have gotten them for $17 when they run a sale. Even with shipping, you could have your finish mower up and going for less than $100.
Marathon Tires Flat-Free Lawn Mower Tire 3/4in. Bore, 8in. x 3.00-4in. | Flat Free Lawn Mower Wheels| Northern Tool + Equipment
I've used one set for two years, no problems other than making sure the grease zerks were tight and I always grease them before mowing. If these aren't the right size, they do have others
yes thanks Gunny i just recieved my 2 new wheels that i ordered from the info you posted. i had a chance to install them and give them a good try to day and they worked good so far. only problems i had was with the old tires one had gone flat and came off bead while waiting for the new wheels and one of the grease fittings on the new wheels broke instantly when i tried to add grease.
for what i paid i can fix a grease fitting. i will be ordering 2 more now that i know that they fit and seam to work well. Thanks again
/ solid finish mower tires #15
Glad they worked out for you, just keep them greased up and keep on mowing!
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
CFG QK18R (A60463)
CFG QK18R (A60463)
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
2018 CATERPILLAR 420F2 IT BACKHOE (A59823)
2018 CATERPILLAR...
