Spiders are taking over my barn
   / Spiders are taking over my barn #11
Get a 1 gallon pump sprayer and mix up some Malathion with water. Very economical and kills most insects including spiders.
   / Spiders are taking over my barn #12
Like the NE we here in the NW (west of the mountains) also do not have the problems other parts of the country contend with; except we don't have heavy snows either. My wife would go crazy down where yo have spiders. All she has to do is look at even the non-lethal types she gets bitten. She has an allergy to all insect bites. The spiders we do have here are beneficial as they catch and eat a lot of other more venomous insects do we put up with them mostly. At least no recluses or widows.
Ron
   / Spiders are taking over my barn #13
Not naming any names but it has been rumored that certain Cajuns and Texecans fatten up a few spiders every year to chase furners out of their stomping grounds. On a friendlier note,11 years ago someone in this thread mentioned killing mud daubers around their place. Granted,daubers can cause distruction but if you have Widows or Recluses,daubers are their archenemy and prey heavy on both. Diatomaceous earth sprinkled into scorpion hiding places(esp cracks in earth and brick near foundation)is safe and effective. Most species of scorpions glow in black light. Pre-teen boys make a game of hunting scorpions. Just be sure they don't carry sledge hammers to kill them on your house siding.:eek:
   / Spiders are taking over my barn #14
I am gonna have to get a pic of the next big one i see. I have only seen small black widows before i moved where i am at now. The big ball part of the big ones are the size of a dime. I was working on my chainsaw last week and i took the engine cover off and one had a nest in there scared me to death. I just want to get them in control before they start getting into the house. One of the big ones had a red stripe on top of her and the hourglass on the under belly.
I know that this is an old thread but... you had an Australian Redback spider [Latrodectus hasseltii] in Louisiana?
Oh yes, you better believe they're venomous.
   / Spiders are taking over my barn #15
When we bought our house the place was lousy with spiders under the porch roofs. I sprayed with this stuff and still to this day, no more spiders. That is 14 years later. They claim 10 years in protected areas and about 7 outdoors.
I also use it on fence posts and in my barn, in fact everywhere. A tiny bit mixes with water and it goes a long way. I use a Wurth pump spray bottle.
Wagtail is right, I got bitten on the leg once with a Redback. It took 2 days but I got real sick and had to have a needle etc
   / Spiders are taking over my barn #16
I used to have a watermellon patch where there was a black widow under every other mellon.
   / Spiders are taking over my barn #17
I garden spray with Talstar Pro from Amazon, if it creeps, crawls or flies... it dies. I apply spring and fall. It even kills stink bugs by the thousands. The stuff is amazing and cheap. I do ridge vents on the roof, all brick on the house and garage areas, siding within 3 feet of windows, my retainer wall... And I spray my front yard to kill skeeters, fleas and ticks. I should buy a few gallons before some tree huggers realize how effective it is and gets it removed from the market. I learned about it from a pest control guy I called for stink bugs, he was too booked up to get to me and told me that this is a broad-spectrum insecticide. It really is a broad killer of creepy crawlers.
   / Spiders are taking over my barn #18
Same here, been using this insecticide for 3 years and it is lights out. I also spot spray red ant mounds. Wet the mound and a 2' ring around the mound and then insert the wand into the center and give it a 5 second stream directly into command and control (the queen).
I spray 2-3 feet of the ground next to the foundation and 2-3 feet up the outdoor wall. Inside I spray sparingly and usually only 2-3 times a year. You know it is time again when you see a live bug, normally you only find an occasional dead one.
I also keep a former windex squirt bottle dosed up for spot treatments.
2 oz. per gallon ratio and this 3/4 gallon will last about 2-3 years. House and barn and about 5 acres of spot spraying ant mounds.
Couple bucks cheaper here Talstar One, Talstar P, Talstar Pro Insecticide - Free Shipping
   / Spiders are taking over my barn #19
I have a procedure that will work and has lasting effect. There are a couple caveats though - the structure should be basically fairly air tight and no animals, including humans, in the structure within 72 hours after treatment.
What you do is find a Rose dusting powder with pyrethrums in the formula. We use to use an Ortho Rose dusting powder. Get half a dozen empty, DRY cans - we cut the tops off AL pop cans. Put 4 or 5 heaping tablespoons of the powder in each can. Locate the cans strategically around the inside of the building and then ignite the powder with wooden farmers matches. The powder will burn, like a 4th of July punk, and give off a smoke.
Be careful where you set the cans with the smoking powder - it will get hot. Close up the structure and leave it closed up until there is no visible smoke inside.
This is VERY effective but is not a company recommended use for the product.
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
1997 WESTERN STAR DUMP TRUCK (A60430)
1997 WESTERN STAR...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
403 (A52706)
403 (A52706)
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
