Splitting Rock
   / Splitting Rock #1
JimMorrissey
Southern Maine (now)
'05/'06 L39 TLB
So I've got this HUGE rock about the size of a kitchen table from what I've been able to unearth, and it needs to go because it's right in the middle of my new road. I've given up on trying to move it. How can I split the top off this thing? I'll bury what remains. I'm thinking that I'll have to rent a generator and drill holes throught the sides, then split it somehow. The rock is something on the order of marble, but softer...heavy are hard, but nothing like granite. Any ideas?
I'll post a picture a little later.
   / Splitting Rock #2
Hammer drill (big one), 3/4 or 1" bit, couple of feathers and wedges and you should be able to reduce that puppy in no time. /forums/images/graemlins/grin.gif
I have a Makita 1 1/2" hammer drill that I use for my rock work and it does great. You should easily be able to rent the drill and bits. One of the best tool suppliers for rock work may not be too far from you: Trow & Holden is located in Barre, VT. Look for "wedges & shims" - always handy for future projects. Figure to place them 6-8" apart along the top of your split - maybe even half way down the sides in some circumstances. Splitting is fun /forums/images/graemlins/smirk.gif - just keep at it. Hint: paint all your feathers & wedges yellow before you split - that way you are much more likely to find them in the dust then when they are stone-colored metal.
   / Splitting Rock #3
There is a compound that you pour into drilled holes. It sets up and expands, like freezing water, fracturing the rock. You place a blanket/cover over the rock so when it fractures pieces aren't thrown too far. I can't remember the name of the product (it was a variation of bentonite) and it wasn't cheap. It was sold at several rental equipment companies around here, which won't help you on the East Coast, but try your local rental shops.
   / Splitting Rock #4
thats not that big we had a rock bigger than our jd 2750 we could cplit so we had to get a backo in and dig a hole nad we pushed it in lol friggin huge so then we seeded the field out instead of pplanting silage corn lol
   / Splitting Rock
Andy,
What tool are you thinking exactly? This is a large rock......You think a few wedges would split big boulder? I checked the site and don't see what would work well to split. There are lots of finishing tools.
   / Splitting Rock
Yeah, we do have that stuff at our local rental place. I'll give it another look. Thanks.
   / Splitting Rock #8
Feathers and wedges were used to build the pyramid. They are still used today to split car sized chunks out of the rock quarry.
Drill holes a little smaller than the diameter of the feather/wedge assy. Insert a feather on each side and wedge in the middle. Now start tapping on each one with a smallish sledge. Pretty soon a crack will form and a chunk will come off. Move chunk with tractor and repeat.
One could probably fab some feathers and wedges out of flat stock and round bar.
Edit: Wedge and shim On the bottom of the page.
   / Splitting Rock
Scott,
The sizes and the prices of the wedges increase dramatically. What size are the best for splitting boulders and how many would be needed. I added a picture to my original post so you have something to reference. Thanks.
   / Splitting Rock #10
Whoa there... I must sound like I know what I'm talking about!
/forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif
Arkansas is not really known for its rocks as we don't have many.
I'm thinking the biggest $4 or the $5 ones would work ok. 6-8" spacing across a long face as Andy suggested. Start smackin' em and they WILL split the rock. Wedges excert many tons of force on the structure of the rock. Even if it doesn't split all the way across, it will open a crack that can be widened with a log splitting wedge or somthing similar.
If using an electric powered drill, try to have an air source blowing the dust out of the hole as the dust will dull the bit fairly quickly. Air powered drills usually have a hole in the bit that blows the dust out as you drill.
   / Splitting Rock #11
Perhaps look at the rock to see if it is layered and would have natural fracture planes. Then try and split along one of those planes.
From the picture I'm guessing there are planes running at a downward angle. It you are lucky it may be slate which slits easily with a hammer and rock chizel.
You could also build a big hot fire that will produce many coals on top of it. Heat it well and then douse it with cold water.
Egon /forums/images/graemlins/grin.gif
   / Splitting Rock
Thanks everybody....This is a topic I've never had to deal with in the past. My last two home sites (subdivided) were built on quarry grade gravel hill. The engineer who designed the septic system said "you are lucky you're not Monkton, because the town would take the land if they knew what was under here". Now I'm dealing with clay and rocks....what a difference /forums/images/graemlins/tongue.gif It's OK though, I'm getting some serious seat time and learning a lot about building a real road. My gravel roads were so stable, I just had to scrape off a bit of topsoil and throw down some sure-pak.
   / Splitting Rock #13
I'd rent a air compressor and jack hammer (80 lb hammer) and break it up in less than an hour.
   / Splitting Rock #14
Do you have to use water with these air powered rock drills to keep the dust down?
If I remember correctly weren't the first air powered drills that were developed for tunneling referred to as "widow makers" because they would fill the opereators lungs up with silica and caused severe lung damage in a matter of weeks.
   / Splitting Rock #15
You don't need to buy the biggest set of feathers & wedges to split a rock. Depending on how it is made up, you can get anywhere from 4" to 2' or more on a split using the smaller devices. A picture and/or description of the type of rock you have locally would help. What you are trying to do is create a fault line across the rock face. Pay particular attention to any existing cracks or veins as they often will tell you the direction of the grain of the rock (direction in which it will split most easily). I am working with granite up here - but it is not always smooth going. Some types of stone have a much "rounder" feel and may have occlusions of various minerals which makes them into non-compliant /forums/images/graemlins/crazy.gifpains in the you-know-what. Sometimes you have to use an abrasive or diamond saw and grinders to work off troublesome areas on those - so I try to avoid them. Some rocks (not around here) are just too soft to split and you have to resort to other methods.
As you drive the series of feathes and wedges in (go along and hit each one at a time) you will feel and hear everything tighten up and sometimes they "sing" just before the break - as in so tight that they chime when you hit them. Everything goes dull when the tension is off though you usually know when the fracture starts. Be prepared to rescue a few of your sets if the fracture line does not follow them - it happens. You can usualy just knock the wedges side to side a little bit and loosen them up but soemtimes have to drill a relief hole nearby.
Someone mentioned dust and silicosis. Serious stuff. If you are working in any kind of operation where the dust is doing anything more then mounding around your drill bit you should wear a good mask. Same rules apply as with motorcycle helmets - what's your life worth? Forget the paper masks - get a good strap on repirator mask with dual filters and prefilters (around $30-50) and change the prefilters frequently.
   / Splitting Rock #16
Hmm, brings up an intersting question for me. What is the best way to drill a hole in rock for the feather and wedges?
I have heard two trains of thought, hammer drill, or diamond encrusted core bits with a no-hammer drill. What is better?
If hammer drill, what kind of bit should one use for rock, a normal HD quality masonry bit?
Also, I have a mounded rock I need to shave down a few inches to place a terrace over. I was going to get a 10" gas saw with a diamond blade and just cut ruts and pop them out. NE1 have an opinion on that (gee, should start another thread, sorry)
   / Splitting Rock #17
If it's just sandstone, you can rent an electric jackhammer, they actually work pretty well. They weigh about 80lbs and run on 120V. I used one to bust up a 20' X20' concrete patio, the concrete was over 30 years old and hard as can be, but it broke it all up in about 5 hours, cost less than $100. Rented it from Home Depot.
   / Splitting Rock #18
No, its granite or whatever we grow here in New England. It is sediment rock, that is, it is layered.
   / Splitting Rock #19
If it's layered it's not granite. You may find it easier to split as it possible could be slate or a form of metamorphised slate which will be harder.
   / Splitting Rock #20
Funny you should bring this up. I am just going through the learning curve on doing this very thing these past couple of weeks. I would like to make some stone steps and have access to some granite from an old quarry on a friend's property. Here's what I've done.
I first went and checked out the price of buying the steps at a nearby stone company--big bucks. So I decided to see if I could split the granite myself figuring that whatever toys (excuse me, I mean tools) I needed would be paid for by the money I saved not buying the stone.... Anyway, attached is the setup I put together.
Basically, it's a high-torque, 12V cordless drill; a 1/2-inch diamond core bit with a water swivel adapter (to supply the water to the bit) [www.ukam.com]; a hand-pump sprayer [Home Depot]; and 20 or so feathers and wedges [www.trowandholden.com]. I have no access to electricity way back in the woods, thus all the portables... People scoffed at the idea of drilling holes in granite with a cordless drill, but....
to be continued....
John Deere 6120M (A57148)
John Deere 6120M...
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
2013 Land Rover Range Rover Sport 4X4 SUV (A59231)
2013 Land Rover...
23105 (A56859)
23105 (A56859)
2005 John Deere 7420 (A60462)
2005 John Deere...
2002 TEREX TA25 OFF ROAD DUMP TRUCK (A60429)
2002 TEREX TA25...
