Start/Stop technology
   / Start/Stop technology #31
The computer uses this sensor to tell the alternator how much to charge the battery. You probably shouldn't be disconnecting it.
Most alternators have an internal regulator that sense the system voltage by the wire at the alternator. I have to believe that this second sensor is more to measure the voltage fluctuations and health of the battery. If draw on the battery like A/C, lights, trailer brakes, accessories, are taxing it too much, then it will read it and limit S/S.
   / Start/Stop technology #32
I have a KIA Stinger with the same Start/Stop feature. The default is on, so every time you start the vehicle you learn to also turn off this feature (push a button) when you fasten your seatbelt. There are a bunch of provisions that the start/stop feature is disabled automatically, you will just have to check your owners manual. I know on mine if it is set in a different mode besides "economy mode" or it the temp outside is above 95˚F, how you brake, etc....
It is annoying and I wish the default setting would be off but it probably has to be on to meet the government fuel requirements.
I do like the "coasting" feature it disconnects the drive shaft so the car's rpm drops way down to about 700 rpm, about half of the RPMs if this feature was not included.
   / Start/Stop technology #33
Guess you Chevy is different than mine.... Ever time I touch brakes its off....
Dale
He is talking about turning the cruise control on/off not setting it with the ability to hit the resume button. If you don't know that it has an on/off feature, you probably have it turned on and are only using the set/resume feature.
   / Start/Stop technology #34
Our new Toyota also has this. I think it's a pretty silly "feature" but I do appreciate that Toyota's implementation is also controlled by brake pressure. You have to hold the brake pedal past a certain point for the car to allow the engine to stop, and it only takes an hour or two of driving to get a good feel for where that point is. The cut off is a little past where I normally hold the brakes at a stop, so it doesn't activate except when I consciously decide to press a little harder, like if I know I'm going to be sitting still for a while. That kind of design detail really makes or breaks the usability of something like this.
start stop vehicles are designed with a much heavier duty starter
I wouldn't worry about the starter wear and tear. I have 100K on mine with no problems.
The starter and battery are designed for this function.
Then they found out it was a non-issue......just drive it.
I have been convinced to forget about it. Thanks everyone for you're help.
Now if I can just remember if I have a nova or a malibu.
I am also going to give that yellow/green thing a try, the next time Mrs.tiller lets me ride with her.
   / Start/Stop technology #37
Dale
No, it doesn't turn off. It releases, but it doesn't turn off. There's an on/off button. There's a set button. There's a resume button. Once you turn the on/off button to on in a Chevy, it stays on forever until you turn it off again, no matter how many times you turn the ignition off or on. In a Ford or Toyota, each time you turn off the ignitions in the vehicle, you have to turn the cruise control on again before you can use the set button.
   / Start/Stop technology #38
You need to drive with one foot on the brake and the other on the accelerator
Tell that to Sammy Hagar...
One foot on the brake and one on the gas, hey!
Well, there's too much traffic, I can't pass, no!
So I tried my best illegal move
Well, baby, black and white come and touched my groove again!
Gonna write me up a 125
Post my face wanted dead or alive
Take my license, all that jive
I can't drive 55! Oh No!
Uh!
So I signed my name on number 24, hey!
Yeah the judge said, "Boy, just one more...
We're gonna throw your *** in the city joint"
Looked me in the eye, said, "You get my point?"
I said Yea!, Oh yea!
Write me up a 125
I can't drive 55!
Oh, yea!
I can't drive 55!
I can't drive 55!
I can't drive 55!
I can't drive 55!
Uh!
When I drive that slow, you know it's hard to steer.
And I can't get get my care out of second gear.
What used to take two hours now takes all day. Huh!
It took me 16 hours to get to L.A.
I can't drive 55!
No, no no,
I can't drive...
(I can't drive 55!)
I can't drive...
(I can't drive 55!)
I can't drive 55!
   / Start/Stop technology #39
Ever time I shut key off.... It turns off cruise off until I turn it on again... Nothing to do with resume cruise after braking.... Don't understand the comment "its on all the time"....
Dale
   / Start/Stop technology #40
Yours is different than mine... Everytime I turn key off.... It kills cruise until I physically turn it back on (nothing to do with reset or resume) .... Been driving this vehicle for long time, think I know about it's kinks and foibles....
Dale
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54756)
(2) LITHONIA...
BUNDLE OF 8" I BEAMS UP TO 49" (A54756)
BUNDLE OF 8" I...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
