Starting A New Septic System
   / Starting A New Septic System #11
About the only yeast that would work is a specialized beer Lager yeast. Most all yeasts work ing the 70's and 80's. Your inground septic tank stays at least in the low 60's, and probably in the 50's year round. Being in the ground like that, it's like a basement, root cellar, or wine cellar. Once you dig down a bit, the ground stays a pretty constant temp(although the exact temp may vary due to individualized variations at the site).
Tha guy that pumped our tank a few weeks ago said to put in thier "box of bogs", which just kick starts the process. Apparently they are the same "bugs" as used by large treatment centers.
   / Starting A New Septic System #12
A septic system is designed(here in NC) for the number of bedrooms, not # of tolets/baths etc. They do that because they figure each person uses x amount of water per day, either flushing, showering, or washing clothes... If you over taxing the system then your going to have problems. A system(tank size and drain field) is designed for a certain GPD(gallons per day) This gives the solids/sludge time to settle to the bottom of the septic tank and so only grey water makes it into the lateral lines and into the ground.
Decomposition in the tank is anerobic(with out O2) and decomposition in the ground in aerobic(with O2). So while most of the solids should be broken down in the tank, if you flow more water into/through the tank than it was designed for then yes some solids may make it out to the field.
A lot of factors determine the amount of decomposition in the tank(temp, PH, and type of solids). Of course grease, bleach, food scraps should not go into the system in any quantity. If your filling your tank up to %50 in 3 years that's pretty quick and you should look into either a larger system or using less water/w3tcompact/icons/hmm.gif.
As far as sludge in the lateral lines, in our LPP system I "flush" the lines every 6 months, I only see a small amount(1-2seconds) of "black" before it turns clear/grey. With a gravity feed system it's harder to do this type of flushing.
A septic system, if designed, installed, and used properly should work for many years without any problems at all, it's when one or more of those 3 aren't when problems occur. Once a system fails, then all kinds of trouble occurs.
The county should have a record of your system(if installed in the last 20yrs for sure) if you have question about size and layout.
gary
   / Starting A New Septic System #13
I agree with you completely./w3tcompact/icons/smile.gif
Around here they are also based on number of bedrooms as well as soil type.
All I am saying is that our 45 year old system is working well because it is maintained well. There are literally hundreds of 15 year and younger septic systems in newer housing developments in our county that are failing. The main cause is that they are plugged up solid. It could have been prevented with regular maintenance and possibly better design. /w3tcompact/icons/smile.gif
   / Starting A New Septic System #14
Hi kip
What size septic tank do you have, and what sort of soakage drain? In this country i think the min size is 3000lts and 45 mts of soakage drain. It is dug to about 1200mm deep and the same wide. A concaved or ( upside down u) perferated poly is layed in the bottom then covered with non porous 2" stone, then a layer of porous non degradable paper is placed over that and then backfilled. It is also encouraged that you grow trees over the top of this drain, to aid transpiration. This link maybe of some interest.
http://www.ahc.sa.gov.au/council/faq/sanitation/septiccare.html
   / Starting A New Septic System #15
If anyone is having a problem with a "sour" leach field, try this link <A target="_blank" HREF=http://www.terraliftinternational.com/>Terra Lift</A>. It did wonders for my front lawn that was oozing black water.
   / Starting A New Septic System #16
A lot of people move from the city top the country and think they can put everything they did living in the city down the drain on a septic. For us, this was my first time, and we weren't given anything on the care or maintenance of the system. The first thing I noticed was that we didn't have a garbage disposal in the sink.
So I'm sure lot's of people stick food scraps, grease, and anything and everything in the toilet down into their tanks that just don't rot too fast. There has been quite a bit of research into the size of a tank(GPD) needed for a normal 3brm house, and while this is for normal usage and even occasion over usage, it can't function on long term over usage.
We studied a system for a k-6 rural school and the weekly/daily demand on that kind of system. Something that has high usage for just a few days per week then rests for 2-3 days. Basically, the soil acts just like another storage area like a septic tank, and when that storage area is full, you can't exceed the area without problems.
It's getting very costly for city's to build major water treatment plants, and the feds are backing off the funding for them, so as communities grow, more people will be on individual/community septic systems. The instructor in my class predicted that in the next few years-5-10 that ALL septic systems will need a operator and regular inspections done.
I good working septic system is the best way to "treat" wastewater and keep the ground water clean.
gary
   / Starting A New Septic System #17
I heard that yogurt works well in a septic tank! It works great tenderizing a steak so why not in the tank!
daedong:
I have to admit my metric isn't that good so I'm not sure about the conversion that you posted.
My system was designed for our three bedroom house. It has a 1000 gal and a 500 gal tank hooked up in a series.
Most systems in our area are elevated sand mounds because the soil did not perc. Fortunately, our soil perced so we were able to install a conventional system. The drain field consisted of three trenches about 19" deep. The bottom of the trench was lined with stone and then the pipe was laid in, the pipe was covered with building paper and covered with more stone and then graded with 12" of soil. The perc rate was 43.1 minutes/inch.
I didn't see the complete installation of the drain field and the design paper work is at my office but this is what I remember.
Kip
   / Starting A New Septic System #19
Kip, what you've got is a Septic tank and a pump tank. Conventional system as far as the drian field goes? Would yours be a gravity feed system? You have no pumps?
Your trench installation sounds pretty normal, though your trenches must be pretty long 50'+.
At 19" here though I believe they'd have to install a LLP system.
gary
   / Starting A New Septic System #20
Intended use of a septic system should put enough bio-mass into the system to get it started. I would keep the laundry bleach use to a minimum for the first couple of months to get the system going.
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
10' CONTAINER (A52706)
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
gps trailers (A56859)
