cat fever
Elite Member
Sounds like it should work out fine.
Is there an advantage to putting up sheetrock before the wood on the ceiling? I'm curious on why to spend the time and money to install the sheetrock first.
A few things;
More insulating value, less outside noise, waste less T&G wood, holds all the insulation where it belongs. (blown in the attic)
At least these are some of the things the builder and finish guys have told me.
I was a finish carpenter / contractor for years. Did many t&g ceilings. Some builders put up rock first, others did not. I could never get a good answer as to why for either method. I know it was easier to install the wood directly to the joists or rafters for the install. I knew exactly where to nail. We had a few warranty calls for loose and or warping boards on the ones that had Sheetrock behind them. Not one call-back or warranty issue on the ones secured directly to the structure.
I could never figure out if it was due to the different expansion / contraction properties or differences in moisture content.
Job looks great, beautiful doors. I'm following your build intently. Your progress is impressive. We are in process of building a small cottage / retirement home. We're going to use the same style of door, with black iron hardware.
Looking at that ceiling makes me want to add some T&G to part of my family room.
