Storing a B26 in a sea container
   / Storing a B26 in a sea container #1
lakeside
Ontario and Quebec
B26, G11000 generator and a G1800
Does anyone know the dimensions of a B26? I'm looking at buying a B26 this spring and then buying a used 20' sea container to convert into a storage shed. The 20' seacan's internal dimension are:
7'8" wide (2.33m)
7'10" high (2.38m)
Door height: 7'6" high.
Total interior length: 19'4"
Ideally I'd leave the ROPS up, but if I have to, I could fold it to park in the seacan.
Thanks
   / Storing a B26 in a sea container #2
Do you mind divulging a ballpark cost of a a 20 footer now. I would think that prices have dropped considering the price of steel and the slip of shipping.
Thanks, BD
I haven't really checked but a quick search shows used 40 footers at $1900 Canadian dollars. Add on anywhere from$100-$500 for delivery.
My idea was to finish to outside with siding and add a pitched roof so the final product would like like a typical garden shed, but one that's really vandal resistant.
   / Storing a B26 in a sea container #4
Here's what I know.
Last year I was looking at B26s. (Ended up getting a 2630) Because I was looking to buy used I would have to go pick it up somewhere. Anyway, I remember that it would fit, by an inch or two, into most rental 24' box trucks. However, the B26 will not fit in my garage. FYI the ROPS/FOPS on the B26 DO NOT fold down.
Just a thought. But have you looked into a cargo trailer. It can be your tractors garage and transportation. Also no building codes to deal with.
Hope this some. Good luck
   / Storing a B26 in a sea container #5
Thanks, BD
I was looking at containers a year or so back and a new, well almost new, one trip to the US, was around $2500. They've actually gone up since then to $2900. Unfortunately the place that had them has sold out in Savannah, GA, their closest location. Now I'd have to go much farther to get one, not worth it to me. A used container is about 50% of a new one at the spot below-
http://www.allstatecontainer.com/hotDeals.php
   / Storing a B26 in a sea container #6
The B26 will easily fit into the container, make sure you vent it for release of condensation to avoid having the machine "sweat" and rust. Let us know how it works out.
   / Storing a B26 in a sea container #7
The B-26 measures 204" long x 89 1/2" high x 60" wide according to Kubota specs. as Curtisfarmer said, it should easily fit.
   / Storing a B26 in a sea container #8
I have a 40' high cube sea container and the High Cube is a must to get the B26 inside. The standard height won't work.
   / Storing a B26 in a sea container #9
Wow, I thought it would have fit for sure, thanks for the pics.
   / Storing a B26 in a sea container #10
I bought the standard container and later bought another high cube. Pictures are of my tractor in old and high cube. Note ropes down in standard container
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
