sudden and violent PTO engagement with new Kubota MX5800
   / sudden and violent PTO engagement with new Kubota MX5800 #21
It probably only stalled because there was too much load on the engine at that moment ... (While the blades were sorting themselves out)
Yep...
Good thoughts and info. Thanks to everyone. I will for sure check out the possibility of replacing a part that could slow the flow of fluid and thereby soften the PTO start. IMO, it stands to reason that the problem is that the hydraulic flow to the PTO is turned on suddenly and has immediate significant force. So, if I can dampen this flow to start, it could be a solution. Yes, the fluids are all good. I checked them all. The PTO shaft on the mower has a slip clutch in line, so presumably that's not the problem. Yes, I raise the mower so that the PTO shaft is in about a straight line with the PTO before I engage the PTO. However, I did notice some shaking of the PTO shaft, so I might need a longer one (or a PTO extension, which I have) for use with the mower. I am aware of the inertia effect of the blades being slung out or not. In fact, when the tractor shut off on one PTO engagement and the tractor wouldn't restart regardless of what else I did, including of course turning off the electric PTO switch, I figured that somehow the "PTO engaged" sensor was somehow still in the engaged mode. So, I disconnected the mower PTO shaft from the tractor PTO and rotated the tractor PTO shaft both ways. Then the tractor started. I took the tractor to the shed, raised the mower, and saw that the mower blades had become stuck together, one on top of the other. I had that happen once before but only when I was mowing and hit an obstacle that caused a blade to bent a little--never when just engaging the PTO. I used a light sledge hammer and got the blades separated. I then went back out and engaged the PTO again, and this time the mower did get up to speed but only with again the violent start and shaking. Once the PTO got up to speed the mower worked well.
   / sudden and violent PTO engagement with new Kubota MX5800 #23
Since this is totally a hypothetical discussion I'll add this.
The PTO clutch is a wet clutch, meaning it's running in oil and is activated by oil pressure. If the activation mode is softened the clutch discs will slip longer before complete engagement is achieved. So, wouldn't this slippage cause premature clutch disc failure?
Not to sound condescending, your tractor doesn't "know" if the PTO shaft of the cutter is attached.
No condensation taken, and never would be. To me, there is no such thing as a bad thought when we are trying to contribute to a solution. And agreed with respect to the electrical circuitry. That is why I couldn't understand why the tractor wouldn't start after it shut down following a violent PTO engagement. I turned the PTO electrical switch off, on and off several times. No go. So, I wondered if there were a mechanical component to the "all is clear" electrical circuit. Stated differently, I thought that if the PTO shut down suddenly, there might be a hydraulic pressure feedback loop or some such to prevent the tractor from restarting when there was a problem with the PTO. So, I disengaged the mower PTO shaft from the tractor PTO, and the tractor started. I don't know why this worked, but it did. I haven't investigated it but to me a logical possible answer is that there may be in the PTO-engagement circuitry a pressure-sensor switch that senses when there is still hydraulic-oil pressure trying to rotate the PTO even though the electric PTO engagement switch is turned off. That's why I tried disconnecting the mower PTO shaft and rotating the tractor PTO shaft both ways. It worked, but I am for sure not saying that the reason is what I thought it might be. Interesting, though.
Another good and pertinent thought. Based on my limited experience to date, I would probably run the risk of premature failure of the discs in order to eliminate the violent PTO engagement of the attachments, especially with the mower, which is my most often used attachment that requires the PTO power.
   / sudden and violent PTO engagement with new Kubota MX5800 #26
I don't think your tractor is that smart. But what do I know. :)
   / sudden and violent PTO engagement with new Kubota MX5800 #27
My Kubota uses a cable operated lever to engage the PTO hydraulic clutch. It specifically states to not soften the start by feathering the lever, fully engage without hesitation. I believe that is to minimize clutch slippage.
   / sudden and violent PTO engagement with new Kubota MX5800 #28
I have a Massey Ferguson with a similar electric PTO clutch. Starting my brush mower....it is almost scary given how bad it sounds. In contrast, starting my PTO wood chipper is about as smooth as can be. Go figure.
I find the same with my Branson's electric PTO. The chipper starts smooth and the rotary cutter makes gnarly noises and vibrates for a while. I think there's a few things going on- the wood chipper has a 24" 200 lb flywheel turning at twice PTO speed (making it effectlvely a 400 lb flywheel). The rotary cutter has a small diameter hub, stump jumper and two blades that weigh about 10lb each. Much less flywheel effect. Yet the tractors' PTO clutch engagement has to be able to handle the wood chipper without slipping too much. That means the rotary's engagement is abrupt.
I think the reason the rotary vibrates when it starts is that the blades are swinging on their pivots, which means the entire assembly is unbalanced. It's made to be balanced when the blades have swung out to the farthest position, not when they're swiging back and forth like a pendulum. A slower start like you can do with a manual clutch would reduce the pendulum effect.
It's unnerving but I figure that the cutter sees a lot worse when it's cutting brush and the forces are low so it's not going to damage the tractor. But if the tractor shuts down, then that's a problem.
   / sudden and violent PTO engagement with new Kubota MX5800 #29
I'm afraid that's the nature of the beast. Do your engagements at engine idle to minimize the shock to the cutter or any other PTO attachment.
Same applies to disengaging an implement...idle down for 5-10 seconds before disengaging the PTO. Makes for a much smoother transition and, undoubtedly, will extend the life of the implement and tractor.
   / sudden and violent PTO engagement with new Kubota MX5800 #30
I think the reason the rotary vibrates when it starts is that the blades are swinging on their pivots, which means the entire assembly is unbalanced. It's made to be balanced when the blades have swung out to the farthest position, not when they're swinging back and forth like a pendulum. A slower start like you can do with a manual clutch would reduce the pendulum effect.
That's right...until those pivoting blades extend and balance out, a cutter will make a heck of a racket. It helps if you keep the RPM low until the blades pivot into position (keep your foot near the throttle if the tractor starts to stall).
   / sudden and violent PTO engagement with new Kubota MX5800 #31
I think it depends on the type of PTO (live, etc), type of clutches (main, overrun, etc) -- if the implement has a heavy flywheel or flywheel action, that easily can overdrive the PTO and transmission/engine after you throttle down. For example, on my wood chipper, it's far better to disengage the tractor's clutch, then throttle down, then wait for the chipper to stop spinning the PTO and transmission before finally disengaging the PTO. If you just throttle back, the chipper's flywheel inertia could over-run the engine and transmission if there wasn't some sort of over-run slip clutch.
On really old tractors, you could disengage the clutch to take load off the engine but of course the PTO and transmission would still be coupled. It was possible for the PTO implement to then keep driving the tractor forward if it was in gear!! I am sure that caused some pucker moments.
   / sudden and violent PTO engagement with new Kubota MX5800 #32
Yep...and there are still a number of old Fords (8N's, 9N's etc.) still in service. With these older machines, if you didn't have an overrunning clutch, you could be in trouble when disengaging the PTO.
   / sudden and violent PTO engagement with new Kubota MX5800 #33
Here's a suggestion the OP can try. (I am sure the safety police here will jump all over it though). The whole problem is that you are up against Newton's 1st law, which is an object at rest tends to remain at rest. There is about 150lbs of mass that is sitting perfectly still, and all of a sudden you are trying to make it turn at 540 rpm's! Hence, it is creating a big shock to the driveline when the PTO is engaged.
So... next time, before you engage the PTO, raise the bush hog about 3ft off the ground. Set the park brake and get out of the cab. Then with your hand, grab one of the blades and see if you can start spinning the blades in their normal direction of rotation. Once it is moving a little bit, jump back up in the cab and adjust the deck height to where the PTO shaft is straightened out as much as it can be and engage the PTO. If you can get the entire drive line spinning, even if it's only turning 5 rpm's, I suspect that *would* reduce the shock a good bit when the PTO engages.
If you try that, let us know how it works. I don't see a problem doing it that way, as long as NO ONE ELSE IS IN THE CAB, when he's trying to spin the blades by hand.
   / sudden and violent PTO engagement with new Kubota MX5800 #34
Sorry, double post.
   / sudden and violent PTO engagement with new Kubota MX5800 #35
I don't understand. How could it "over-run" the engine? The engine is already turning at full PTO speed -- the flywheel of the chipper can't make it speed up. It always seems to me to let the engine come down to idle speed so you slow down the flywheel quicker, then disengage and let the equipment come to a stop from there. (This of course if you don't have the old setup where the PTO can drive the transmission.)
   / sudden and violent PTO engagement with new Kubota MX5800 #36
It can't. Lots of confusions around this. There is a big difference between a tractor PTO clutch, a PTO drive shaft slip clutch, and an overrunning clutch. Each have unique features and are independent from one another. Overrunning clutches, if used, are on the equipment itself, most often implements with a flywheel.
   / sudden and violent PTO engagement with new Kubota MX5800 #37
Anyone that engages a PTO driven implement at full PTO RPM probably needs to review the owner's manual a few more times. ;)
I'm not going to get near the underside of the mower while the tractor is running. I'm going to a/ check with the dealer, b/ follow up on the suggestion about a mechanical/hydraulic way to dampen the PTO engagement a little, and c/ see what experience Travis and others at EA have and what suggestions they have. I will report back one way or the other. Thanks again for the feedback.
   / sudden and violent PTO engagement with new Kubota MX5800 #40
Lub your PTO shaft ...the inner on the outside....and the outen on the inside...to get a good slide for when shaft is not straight ,
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
(4) 775/65R29 TIRES (A60430)
(4) 775/65R29...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
John Deere 5045E for sale Auction
John Deere 5045E...
2007 GENIE Z60/34 TELESCOPIC BOOM LIFT (A60429)
2007 GENIE Z60/34...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
