SUDT vs 80-90 for standard trans
   / SUDT vs 80-90 for standard trans #1
kw1
West virginia
Kubota L4400
hey guys I was thinking about using 80-90 instead of SUDT on my L4400 because it is standard transmission and I keep it inside with a block heater during the winter. Is there anyone out there who thinks this is a good/bad idea.
   / SUDT vs 80-90 for standard trans #3
If it's a standard transmission you may want to consider UDT.
It's cheaper than the SUDT. I don't think you want to put
80-90 in your transmission. If you have a manual see what it says to use.
   / SUDT vs 80-90 for standard trans #4
   / SUDT vs 80-90 for standard trans #5
The oil in the transmission is also used to run the hydraulics. The hydraulic pump would have a coronary
   / SUDT vs 80-90 for standard trans #6
yeah you are right guys I can use 80-90 on the front axle case only However most of the people around here have super UDT only and I only need UDT.
RIGID TOOLBOX (A52472)
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A56138)
2014 INTERNATIONAL...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
CAT EXCAVATOR BUCKET (A55745)
CAT EXCAVATOR...
