SUDT vs 80-90 for standard trans
   / SUDT vs 80-90 for standard trans #1
kw1
West virginia
Kubota L4400
hey guys I was thinking about using 80-90 instead of SUDT on my L4400 because it is standard transmission and I keep it inside with a block heater during the winter. Is there anyone out there who thinks this is a good/bad idea.
   / SUDT vs 80-90 for standard trans #3
If it's a standard transmission you may want to consider UDT.
It's cheaper than the SUDT. I don't think you want to put
80-90 in your transmission. If you have a manual see what it says to use.
   / SUDT vs 80-90 for standard trans #4
   / SUDT vs 80-90 for standard trans #5
The oil in the transmission is also used to run the hydraulics. The hydraulic pump would have a coronary
   / SUDT vs 80-90 for standard trans #6
yeah you are right guys I can use 80-90 on the front axle case only However most of the people around here have super UDT only and I only need UDT.
2016 R and R Products 331 LP Reel Mower (A55851)
2016 R and R...
KUBOTA KX057-5 EXCAVATOR (A52707)
KUBOTA KX057-5...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A57024)
PENDING SELLER...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
MISC PALLET OF DRIVELINE PARTS (A55745)
MISC PALLET OF...
