SUDT vs 80-90 for standard trans
   / SUDT vs 80-90 for standard trans #1
kw1
West virginia
Kubota L4400
hey guys I was thinking about using 80-90 instead of SUDT on my L4400 because it is standard transmission and I keep it inside with a block heater during the winter. Is there anyone out there who thinks this is a good/bad idea.
   / SUDT vs 80-90 for standard trans #3
If it's a standard transmission you may want to consider UDT.
It's cheaper than the SUDT. I don't think you want to put
80-90 in your transmission. If you have a manual see what it says to use.
   / SUDT vs 80-90 for standard trans #4
   / SUDT vs 80-90 for standard trans #5
The oil in the transmission is also used to run the hydraulics. The hydraulic pump would have a coronary
   / SUDT vs 80-90 for standard trans #6
yeah you are right guys I can use 80-90 on the front axle case only However most of the people around here have super UDT only and I only need UDT.
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
HYDRAULIC MOTOR AND PUMP ON A SKID (A55745)
HYDRAULIC MOTOR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56138)
2018 FREIGHTLINER...
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A55314)
(NEW) 2022...
More info coming soon! (A53421)
More info coming...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
