Snow Attachments Survey - plowing snow with a rear blade
   / Survey - plowing snow with a rear blade #1
Wheeldog
NW CT
Kubota B2410HSD
This topic has been covered quite a bit already, but I thought a little survey might bring together some good information. If you use a rear blade to plow, would you be willing to share:
- blade make and size
- tractor make and model
- length of driveway and whether it is paved, gravel, or dirt
- use skid shoes or not
- use blade for landscaping
Be sure and use a #2 pencil. Partial credit if you show your work. /w3tcompact/icons/smile.gif
Thanks.
   / Survey - plowing snow with a rear blade #2
I use a LandPride 2572 blade with hydraulic TNT on my Kubota L3010HSD. One thing that's typically overlooked in a blade used for snow is moldboard height. Some of the cheaper blades with 12" moldboards aren't much use in deeper snow; look for something with 15" plus. Ag tires loaded, with Norse ice chains on the rear. These chains are not for wimps; they have large spikes that reduce asphalt to crumbs and make for a bumpy ride. I plow one short driveway and another that is about 150' long, plus 1/4 mile of unmaintained town road. The long driveway is gravel, but everything else is dirt. I don't use skid shoes as they tended to break off with annoying regularity in the cold. I generally plow snow driving forward with the blade angled sharply to the side. When plowing over the gravel I still drive forward, but with the blade reversed so I don't scrape all the gravel away.
Landscaping? Heck, that's why I have a chainsaw and a logging winch! /w3tcompact/icons/smile.gif
Pete
www.GatewayToVermont.com
   / Survey - plowing snow with a rear blade #3
Bushhog 35-7 (7 foot) blade, covers tire when angled at 45 degrees
John Deere 790, MFWD, R4's, TNT
300 foot of gravel driveway
no skid shoes
have box blade for landscaping, but have used rear blade on occassion
haven't had a chance to plow snow with JD, didn't snow deep enough last winter, and what we did have cleared with my Craftsman 22.5 hp with rear blade.
   / Survey - plowing snow with a rear blade #4
Wheeldog,
- Woods RB60 (60")
- JD 4100 HST
- ~200 ft paved
- will be using skid shoes
- use the rear blade to move soil, gravel, reclaimed soil, etc.
Lost my #2, ok if I use a #1. /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Terry
   / Survey - plowing snow with a rear blade #5
Woods RB1572 (72")
Kub B2710
100' paved
no skid shoes yet - need to get some !
purchased 1/01 - used twice in snow , never used for landscaping
   / Survey - plowing snow with a rear blade #6
- Farm King 60" blade
- Kubota B2410
- ~250 ft gravel
- no skid shoes...thinking about adding them
- I've used the blade quite a bit for spreading topsoil
Only thing I would change is I would buy a heavier duty model that tilts. I have to adjust the side link which is a pain and only does so much.
Kevin
   / Survey - plowing snow with a rear blade #7
Cheapie TSC 5' Blade
Kubota L3000 4WD
125' paved
no shoes
No landscaping w/it
Beats the heck out of shoveling/w3tcompact/icons/smile.gif.
Paul
   / Survey - plowing snow with a rear blade #8
LandPride RB1560
Kubota BX2200
200' asphalt driveway
Skid shoes
Used also for filling in some low-spots and ruts in combination with a ripper (to break up clay first)
Thanks to all who have replied so far. I meant to throw in my own info before, even though I don't own a blade yet:
- ??? 6' blade
- Kubota B2410
- 150' paved drive + turn-around area
- leaning toward skid shoes
- may use the blade for spreading/leveling topsoil, etc.
Rob
   / Survey - plowing snow with a rear blade #10
Woods RB1572 without shoes
Kubota B2710 with R4's not loaded
300' paved drive
have used blade for minor grading to level off the garden
primary use is to plow driveway and used extensively last winter. We had one storm 22" and several others in double digits and the blade worked great.
iDrive TDS-2010H...
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
