Taking down trees with tractor help
   / Taking down trees with tractor help #71
That rotted tree looks like a good opportunity for a Darwin award... Rotted tree tops and branches can get you in a hurry. If you have had a chance to watch the Axe Men series on the history channel. The guy was operating a grapple cutter. It knocked loose a branch that came down heavy end first and hit the roof of the Grapple cutter. That had 1" thick bullet proof lexan glass. The branch went through the glass and nearly took out the operator...
Food for thought........
   / Taking down trees with tractor help #72
I once had the opertunity to watch an expert :confused: crew take down a very big oak tree in my neighbors yard. The professional crew had a chevy luv truck tied to the upper end of this tree that had its limbs cut off.
They cut a wedge out of the tree in the direction of the truck and put tension on the rope before making the final cut. As they cut through this huge tree trunk it started to fall away from the truck back towards the house.
The truck started to slide accross the yard with increasing speed until the little crome bumper shot up into the air as it was ripped from the truck. The tree cleanly cut the cornner of this old guys house off as it came down. :eek:
If you have a tree wanting to go the wrong way then take little chunks off the top until its not a danger.
   / Taking down trees with tractor help #73
Not that this is the only thing that's moronic about this, but they had the tree hooked up to the bumper? :confused: They should have hooked it up to the FM antenna or perhaps a windshield wiper - both if they wanted extra safety.
   / Taking down trees with tractor help #74
Oak is such a heavy dense wood that it would scare me seeing a little truck attached. Plus it grows so gnarly that it isn't as centered as an evergreen..I had the chance to work on oak when I did Missions work in Mississippi for 3 weeks after Katrina did her deed.. That is amazing wood. We don't get much oak up here in Washington. They let it grow out over power lines on streets. Around here the wood is too soft to let grow out like that in hazard areas. Plus we get snow and ice that tends to break branches and trees..
Bummer for the home owner to have that happen..Getting high up in a tree for good leverage is a bonus. And taking off branches that are putting weight in the wrong direction helps..Even PRO'scan have a bad day....:(
   / Taking down trees with tractor help #75
I miss all the fun :(
   / Taking down trees with tractor help #76
C'mon ! You don't expect us to believe this story, do you???
We all know the last running Chevy LUV rusted into the ground back in 1983 !! :D :D
   / Taking down trees with tractor help #77
Did you notice how the story started? "I once had the opertunity to watch an expert crew take down a very big oak tree"
It was in East Moline IL. I had just started dating my first wife and yes the year was 1982!
   / Taking down trees with tractor help #78
:eek: maybe 25 years ago i hooked a rope halfway up a poplar, then ran it through a snatch block and cleverly attached it to the trailer hitch of my wifes chev astro mini van. Thinking I had her secured, I started cutting into the poplar.maybe 60-80 feet tall. Sure enough the wind caught the crown and started pulling her in the opposite direction from that which was intended. Problem was, this was February...my driveway was ice and I turned to watch this tree pulling my wife's van along the icy driveway straght at me. There was little danger though because the tree fell onto a power line and I watched a pretty spectacular light show for a few minutes before I put about 40 or 50 residents on the lake out of power until Hydro came out and fixed the problem.
Should've seen the looks on their faces
   / Taking down trees with tractor help #79
Picture a "LOL" smiley here repeated over and over. That's absolutely hysterical!
   / Taking down trees with tractor help #80
davitk said:
To add to Pat's post, the way I understand it is good old boys minimum safety requirement = cooler full of ice. We all know warm beer sucks.
Yes, sadly it is true. While I am not necessarily proud of it, it is a scientific fact that the more beers (or margaritas, or whatnot) that have been consumed, the larger the tree you can push over with your loader.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2023 Chevrolet Tahoe FL SUV (A59231)
2023 Chevrolet...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
FENCE PANELS (A58214)
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
