TC24DA broken seat....time for a diet?
   / TC24DA broken seat....time for a diet? #11
What usually happens with a shuttle shift or HST tractor is the rather rapid change of direction imposes large enertia forces via the drivers body weight , even mowing around trees will put sideways thrust on the mounts on a manual trans tractor . It may help to use large body washers above and below the seat bolts to help spread the the twisting forces on the sheet metal .
   / TC24DA broken seat....time for a diet? #12
A real cutie you have there Andy. I see you are busy changing diapers, perhaps?
   / TC24DA broken seat....time for a diet? #13
AndyM said:
I've got the same cracks on my TC18
Andy, I hadn't heard from too many TC18 owners with that problem. I'll have to keep an eye on mine now.
   / TC24DA broken seat....time for a diet? #14
I received my warranty replacement from NH today at no cost. It looks like there has been some improvements to the bracket. Basically, the area where the seat attaches has been increased to a double thickness. I'll try and take some pics and post later.
   / TC24DA broken seat....time for a diet? #15
My tc24d broke in the same way you described. I added some reinforcement and use larger washers at the mounting bolts.
   / TC24DA broken seat....time for a diet? #16
Yes, please do! Mine just broke this past Sunday, with 350 hours and just over 3 years old.
Thanks
   / TC24DA broken seat....time for a diet? #17
I bought my TZ18 used with 50 hours on it. I noticed that I do not have the added bracket in mine. At the front of my seat ot looks like the metal has dented in a little where the seat bolts down. So all I have to do is call the dealer to get the new bracket? I will put it on myself.
   / TC24DA broken seat....time for a diet? #18
Sorry, it's been a little while since I posted last. I had a trip to Orlando, then another to Auburn, so I haven't had a chance to post pics. I did swap the seat bracket with the warranty replacement one. In the pics you can see where the metal under the bolt area is now double thickness. It only seems to be tack welded on, so it may not stay attached long. I still have my original which I plan on repairing and beefing up considerably. Once that is done, I will swap them and beef this one up a bit as well. Replacement was pretty simple. Remove seat and attached bracket. 2 bolts on floor on each side, and one in the wheel well each side. Remove parking brake and 3-pt lift return spring and a little maneuvering it is out. Reverse everything for installation.
   / TC24DA broken seat....time for a diet? #19
Thanks jeffghs, much appreciated
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2004 Ford F-250 Flatbed Truck, VIN # 1FTNW21P84EA26642 (A57453)
2004 Ford F-250...
1996 Dodge Ram Pickup Pickup Truck, VIN # 1B7KF23Z7TJ152725 (A57453)
1996 Dodge Ram...
Hydraulic Excavator Thumb (A57454)
Hydraulic...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
