Good call on the sediment bulb. It, along with the fuel filter, was full of crud. I cleaned it out, and cleaned out the filter as good as I could. I ran into town to buy a filter, knowing that the dealer was open on Saturdays. What I didn't realize is that they closed at noon. I got there at 12:30.
I'll definitely be picking up a fuel filter on Monday, along with the parking brake (that finally came in ). Yes, it was a pain to start the tractor after cleaning out the sediment bulb, but I followed the service manual procedure on bleeding the fuel system. Of course, I tried to start the tractor immediately after cleaning out the bulb, and it ran for about 30 seconds and then died. Bled the system, started it back up. It ran rough for a minute or so, but then went back to normal....
While I was in town, I picked up some CRC additive. I got the anti-gel / lubricity / water getter ridder one, where 12 oz is supposed to treat 125 gallons. I dumped in a little less than an oz in my 5 gallon can. I also bought the fuel dryer version since it was supposed to remove water where-as the first "helped to remove" water. The second one also treats 125 gallons, so I dumped in a little less than an oz.
I also changed my air filters (both of them) out on Saturday. The larger one said 589.1 or 10-02, so I have to assume the smaller one has never been changed out.
Since the dealer was closed, I couldn't change out the oil pressure switch. Upon closer inspection on the existing switch, the bad news is that it looks brand new, with some scuff marks from what appears to be a wrench, so I'm not 100% certain that switching it out will fix my problem.
The good news is that with the fuel filter cleaning and the air filter change, my oil light goes out at 1200 RPMs vs. the original 1500 RPMs.
I put another 30 minutes or so on the tractor, and didn't have the stalling or hesitation, so once the fuel filter is changed out, that problem should be solved.
Even though the engine oil looks new, and the filter looks new, I'm going to get replacement filter and oil, and just start changing that out, and go from there.
Quick disconnect for the FEL is leaking again, and I raised the front end of the tractor off the ground with the FEL (no curl), shut it off, and walked away. Came back 15 minutes later and it was back on the ground, but the leaking on the qd is for the raise / lower function, so no surprise. Adding that to my shopping list.
One problem at a time, right? Of course, I'll have another week of paying work before I get to put more time on the tractor....
