TC33D temp. guage not working. Any idea's?
   / TC33D temp. guage not working. Any idea's? #21
Re: TC33D temp. guage not working. Any idea\'s?
could it be bad thermastat? i had a bad t- stat in winter and temp stayed down
   / TC33D temp. guage not working. Any idea's? #22
   / TC33D temp. guage not working. Any idea's? #23
The engine is coming up to temperature. This is an electrical failure in the instrument cluster.
Bob, you devil you, the barn is only heated if and when I'm working there. The heat is not for the tractor it's for me. /forums/images/graemlins/wink.gif
   / TC33D temp. guage not working. Any idea's? #24
   / TC33D temp. guage not working. Any idea's? #25
I had the same problem with the temp guage on my NH TC33D. I checked it by grounding the wire on the sending unit. By the way the sending unit is on the side of the cylinder head. It didn't work and a dealer replaced the guage it lasted about two months. Again, it went out. Another, dealer came by and checked it and they had to replace the entire instrument cluster. It had drawn moisture and evidently blown something a diode, capacitor, or something. SO they replaced the whole cluster and so far have had no more troubles.
   / TC33D temp. guage not working. Any idea's? #26
   / TC33D temp. guage not working. Any idea's? #27
</font><font color="blue" class="small">( Bob, you devil you, the barn is only heated if and when I'm working there. The heat is not for the tractor it's for me. /forums/images/graemlins/wink.gif )</font>
I have seen you with your TC40DA SS. I am sure you leave the heat on a little longer just for yor baby /forums/images/graemlins/grin.gif
Bob
   / TC33D temp. guage not working. Any idea's? #28
Bob
   / TC33D temp. guage not working. Any idea's? #29
My panel seems to fog whenever I wash the tractor off. The first time, the flasher indicators came on and flashed even though the switch was in the off position. I haven't put a whole lot of water on the dash since.
   / TC33D temp. guage not working. Any idea's? #30
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2015 Rogator RG1300B Spreader/Sprayer (A50657)
2015 Rogator...
2006 Peterbilt 379 T/A Sleep Cab Truck Tractor (A49461)
2006 Peterbilt 379...
