Tearing up the grass
   / Tearing up the grass #1
LittleBittyBigJohn
Veteran Member
Central Arkansas
John Deere 1025R, Kubota ZD1211
I read in the R1 vs R4 debates how the r4 will not tear up the grass as bad. Can someone elaborate on what that means? Does that mean they will leave less ruts in softer condition or just that they will pull out less grass when turning. My house is closing in a couple weeks and I will be on the prowl for a tractor shortly after. I am leaning towards R1 tires just for general utility as the only real benefit I see to the R4 is just "easier on the lawn". My thought is that if the ground is soft enough to leave a rut (compacted tracks) either tire will probably do it. My ground is hard enough in the summer the R1 will not/ should not leave any impressions. It seems to me that there would be a narrow window of time where there would be much difference.
I put bar tires on my commercial zero turn and they do really well. I have a hard time with the thought process of putting a tire with less traction on a tractor? Maybe there is more to it than I think?
   / Tearing up the grass #2
Think of following the same curving path across your lawn. With an R4 you can cover the same path 3 or 4 times without tearing up the grass. With an R1, be expecting the grass to tear the 2nd time you follow that curving route.
I used R4's on the lawn of an RV park that I owned. I was very happy with them, but made it a point not to create a path. Now I own a cattle farm. I don't work in dirt - I work in pasture. I'm still happy with the R4's, and would not replace them with R1's.
   / Tearing up the grass #3
What size tractor are you considering?
what else will you do besides mow the lawn with this tractor.
I have R1 on my 2400H Branson and yes the front tires will leave marks when turning sharp at speed or if locked in 4WD.
no issues with tracks even with full bucket of dirt on dry lawn.
   / Tearing up the grass #4
An R4 tire is wider. They make quite a bit of difference on soft ground. Unless your goal is maximum traction I’d get R4s. They support a loader better, they last longer, they’re more puncture resistant, they’re easier on the grass. The con is they don’t get as much traction.
Looking at Kubota MX or JD 4 series size tractor. Other than mowing and bush hoging at my place, I will keep a decent size garden and general chores. I have 11.5 acres that we just moved on to that was about 90% animal pasture so I would like to level it up over time, dig a little here, move it to over there, etc. Also my sister and her husband are planning on purchasing a large unimproved piece of property for the whole family to enjoy. As much as they have done/ been there for me, I want to do as much as I can to help spruce it up when the time comes. I don't really care if the grass gets scuffed up a little. I'm thinking more about ruts or compacting enough to kill the grass in the tracks, and I'm thinking both would probably do that? I would prefer to get R1 just because it's my first tractor and I really don't know how I will ultimately use it. I think I would rather have more reliable traction and mark a little vs not marking as much and reducing the utility of the tractor. I expect that during the dry months either tire will probably be pretty similar and I would need to be more careful in the damp, either marking the ground with the R1 or spinning the R4.
   / Tearing up the grass #6
I would go with the R1s, but that is my personal choice for traction and the only thing I really concern myself with. While my tractor that I have now is for my home at one time I did do farm work using real tractors and I would not have any other kind of tire.
Like you, what I mow was once pasture/hay lot and my "lawn" is really just hay and clover and whatever else was growing here that I have mowed into submission. I don't really worry about taring it up, and when dry I have never seen were my R1s tare up the "lawn". The only exception to this is when it is extremely wet. Last month (July) it rained here more days than in recorded history, at least according to the weather man and there were a couple of places where I dug in a bit because it was a bit muddy. Even then it did not kill any grass and you couldn't even see the tracks after a couple of days. On the other hand to me it is just lawn and I care very little about it being "pretty" or up to my neighbors standards.
You're also looking at a tractor that is significantly heavier than mine and this will make a difference. As well as the fact that other say the tires might be narrower.... there is no difference in tire width for my tractor for the different tire types, but I cannot speak to what effect narrower tires will have.
In any case, if you concern is traction in a field then I would go with the R1s.
Oh also, I do have a 60 commercial ZTR that I will use a lot for mowing still. I would only use the tractor on the large open places and do the detail with the ZTR. I can also mow the 3 acres I have set aside for yard completely with it in the damper months if I need to. Obviously the rough non yard areas would be with a rough rotary cutter behind the tractor.
   / Tearing up the grass #8
I have turf front tires and r1 rears. My tlb isn't 4wd a d I've never got stuck and they don't tear the grass up
   / Tearing up the grass #9
Regardless of tire type, some tractors will scrub the sod more when turning sharp. Test drives are so important and it helps to do it behind the shop on gravel. If the front tires leave scrub marks or grooves while on the gravel, it will also do it to your yard. In the past, some makers have had to warranty front axles because customers complained about torn up grass. Different caster/camber/toe-in would make a big difference.
   / Tearing up the grass #11
I have run R1 tires for 30 years and never had any issue tearing up grass. And they mash grass a lot less because of less surface area.
   / Tearing up the grass #12
I too have R1 tires on my New Holland. I try not to turn 180 in soft ground or wet grass. I'm lucky because I can mow forward or backward with the hydro and 3 pt Landpride finish mower. My neighbor asked me once if it hurt my neck or back turning almost sideways to mow backward? I told him that at my age that I needed to stretch whenever I got the chance and it was like a exercise program.
   / Tearing up the grass #13
R4 will last more longer. Usually a thicker ply. More surface contact area. Once dad had tractor that wouldnt start. It was the neutral safety. He had a 14' disc on it. Then it rained a good bit. So dad and I were in the 1 ton flat bed with good mud grippy tires. My brother came in his 5610 4x4. We un hooked the tractor and pull started it because disc was down. Then we hooked all back together and left. Dad's truck was rooster tailing mud trying to go. Them tractors barely left a mark on the ground. Amazing to see that.
   / Tearing up the grass #14
I have 80 acres. There is about two acres of lawn around my house and outbuildings. I've had two tractors - both with R-1 tires, both with loaded rear tires.
My current tractor - Kubota M6040 - weighs 10,100 pounds. I have a defined path out of the carport where the tractor is stored. This path takes me out to the remainder of the property or down my mile long gravel driveway.
I simply don't go traipsing around on my lawns with the Kubota. I have a riding mower to cut my lawns.
Depending upon the time of year - the Kubota would either scuff up the grass or, in the spring, leave some fairly deep ruts.
R-4's on my 10K pound Kubota would produce very similar results.
The point being - when you have soft ground - stay off of it whether you have R-1 or R-4 tires.
Pretty simple .........
This is pretty much my thought as well.
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59905)
2021 CHEVROLET LCF...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
