Texas Grapple Shootout
   / Texas Grapple Shootout #311
1) We agree on this. I pointed it out as some folks who have not used a grapple worry that narrow grapples cannot pick up trees which is obviously not the case. Technically they can pick up even bigger trees as they have more net lift capacity than a tractor with a larger heavier grapple.
This seems so obvious to me since I have multiple grapples but to someone selecting their first grapple they tend to think bigger, heavier grapples can carry more.
   / Texas Grapple Shootout #312
I know. It is the All American way to assume that bigger equals better, stronger, faster etc. Sometimes we forget that small can be beautiful (and more effective) too.
   / Texas Grapple Shootout #313
2) Breakout force on a root that you have a tine under is affected by having extra tines. That is why rippers, which aim to maximize force on roots, have only one tine. True that if you are digging in fine sand and have extra tines they will not diminish the breakout force on the root in any meaningful way, but if there is sod or rocks or other roots in the area then the breakout force on the target root is diluted. If extra tines were of no consequence, there would be no reason for backhoes to use rippers instead of buckets.
4) I am well aware that lift at pivot point is not the important number. However, a heavier grapple (say 85lbs heavier) is actually cutting lifting capacity more than 85lbs because the grapple weight is forward of the PP. So your grapple has basically about 100-150lbs less net lift capacity than the identically constructed 48" grapple. Not such a big amount but probably 5-8% of your total lift capacity. If you had one of the typically 600lb heavy duty 72" grapples that many people advocate, you'd pay a much bigger penalty and lose perhaps a quarter of your lift capacity compared to a 48" grapple. Perhaps you have never tried to lift something you didn't have the capacity to lift. I have. Every little bit of capacity counts. As for ballast, the same principle applies. If you have an extra 200lbs hanging off the front of your tractor, you have about 200lbs less down force on your rear tires. I have lifted boulders with my grapple that left me with barely the traction and control I needed to move despite having a backhoe mounted. Unless you want to carry around excessive ballast all the time, it does matter how heavy your FEL implements are, especially when lifting extreme loads.
5) Basically yes but the same concern about bulldozing and hitting an object off center (especially hitting a stump or big rock with the edge) is the same for buckets and grapples. Usually you don't plow into unexplored brush with a bucket but that is a typical task for a grapple. That grapple edge is a potential vulnerability. A 48" grapple has it's edge right about in line with the FEL arm so there is essentially no twisting force when you hit a stump etc. (still not great to ram a stump with skimpy CUT FEL arms!!) Note that bulldozers, which are designed obviously to bulldoze, have their "FEL" arms as close to the blade edge as possible and that those arms are fat and short. FEL arms are not designed for bulldozing and anything that increases twisting forces on them is bad.
6) In the case of grapples on CUTs, a reasonable argument can be made that cheaper is better if the cheapness is achieved through narrower grapple with only one upper arm/jaw. Cheapness can go too far however and there have been a few threads here on manufacturers who use 1/8" thin wall square tube for frames on their economy grapples. That is to be avoided. 1/4" has been shown to be perfectly adequate but it is possible to crush 1/8". I don't know exactly which manufacturers were using 1/8" in the past nor do I know if any still do. Anyone buying a grapple should ask specifically what wall thickness is used though. NEVER buy a 1/8" square tube wall thickness grapple unless the ONLY thing you intend to do is pick up loose brush.
2- A little bit of sod and dirt is not going to hurt breakout force when you are trying to get out a root.
4- Not, really. If my grapple was 85lbs lighter I could lift 85lbs more in it(without getting technical). I have lifted heavy loads, see post 288. I have found with a grapple you need a good ballast. You are going to work your loader harder with the grapple than you do with any other attachment. It is not uncommon to hit the loader relief while using a grapple. So you should have max ballast on while using a grapple.
5-A 4' grapple may be in line with the loader on your DK40 but if won't be on a smaller CUT.
6- They cut corners everywhere in the cheap grapples I have seen. They leave out some key features that a grapple should have. Most are not designed for a CUT either. I think think a premium grapple that is designed for a CUT is the way to go.
Tennant 800 Ride-On Street Sweeper (A55787)
Tennant 800...
Galvanized steel fence (A53424)
Galvanized steel...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
High Lift Ratcheting Off Road Utility Farm Jack (A55787)
High Lift...
LOT LOCATIONS (A56129)
2020 NISSAN Versa Sedan (A55758)
2020 NISSAN Versa...
