Farmwithjunk
Super Member
Soundguy said:I'm not sure I've ever seen a ford or ferguson type tractor 'jump' into gear unless it was being helped by a pants leg or an arm reaching for a tool.
If it bothers ya.. jack the rear axles and put them on secure stands/cribbing... ( not on jacks alone.. )
Internal hose colapse on suction side is possible,, though lower on my list of things to normally check.. however in your case.. you are plowing thru the 'normal' overheat reasons.. so checking the hoses is in order.
post back what you find.
Soundguy
Take the 1-2-3-4-R shifter AND H-L shifter out of gear. Odds of BOTH jumping in to gear are astronomical. Never seen EITHER jump in to gear. Non-syncro shifting doesn't jump into gear without help generally.
I chased a "hot engine" for months once upon a time, just to find out I had a bad sending unit AND a bad gauge. Is the engine REALLY overheating?
