Soundguy said:
My sentiments exactly. I've yet to see a manual non synch tranny 'fall' into gear.
I've seen em started in gear various ways.. and I've seent hem pushed into gear by reaching over, or climbing off. Ditto again on the H/L shifter... odds of both 'falling' or getting knocked into gear at the same time are of fthe charts.
I agree on the hot engine issue. He's running out of 'reasons' for why it would / could be overheating, and is now into the 'grasping for straws' area ..
I'm eager to find out what the final verdict is..
Soundguy
I may be making some progress.
Decided to check the temp gauges. Used the pot of hot water on the stove method. My reference sensor was my meat probe with digital readout (a Williams-Sonoma gift from one of the kids). It's the kind that has the sheathed probe you insert into the meat. A metal shielded cable connects the probe to the readout.
Checked the first temp gauge that I installed as a replacement for the one I got with the tractor, which was completely shot. It has a Cold-Normal-Hot scale and is an el cheapo unit I bought from yesterday's tractors, IIRC.
As the water heated up the gauge stayed pegged on cold. At 127F the pointer jumped upscale to the part of the scale where cold and normal ranges meet. At 186F the pointer reached the start of the hot range and at 207F the pointer reached the end of the hot range. So this gauge probably has a real cheap movement with a lot of friction to overcome before the pointer starts moving upscale. Previously I thought that the pointer jump was connnected with the thermostat opening. But I've checked that the thermostat starts to open in the 180-190F range, so that pointer jump at 127F has nothing to do with the thermostat.
I repeated the test with the other new temp gauge, the one with the numeric scale that reads from 130F to 280F. It's a cheap gauge from NAPA. The pointer stayed pegged at 130F until the water temp reached 149F at which time the pointer jumped upscale to read 152F. Here are the (temp gauge, ref gauge) readings up to the boiling point:
(170F, 169F)
(180F, 182F)
(190F, 190F)
(200F, 199F)
(210F, 207F)
(215F, 212F)
Not bad agreement considering that the temp gauge is a cheapie.
So I installed the temp gauge with the numeric readout, installed the new 180F thermostat, installed a new engine block draincock. Filled the radiator/block with about 9 quarts of coolant (system capacity is 10.5 quarts).
Started the engine, ran for 10 minutes. Temp gauge stayed at 130F. Topped off the radiator with another pint or so of coolant. Ran the engine for about 15 min. Temp gauge still reading 130F. Top radiator hose cold. Bottom radiator hose warm. Bypass hose and hose from block to pump inlet are both pretty hot. The block is hot to the touch, but not painfully hot.
I know there's coolant in the block because I've drained the block several times and got a real gusher out of the draincock. Also get good flow out of the temp sensor hole when I remove the sensor.
Need to run the engine longer and see what happens. Work for tomorrow. The barbeque is just about ready for the steaks now. Bone apetite.
