They started my new roof today...
/ They started my new roof today... #41
I'm not a fan of heat, but I much prefer to roof with tar paper/ roofing felt, and asphalt when it hot. They set and bond so much better.
I guess I think that there is tar paper and there is tar paper. I've seen some that weren't much thicker than normal paper (like that's going to last...), and there is roofing felt that is an 1/8" thick.
There are a number of homes around here that have been reroofed with synthetic underpayment and glass solar tiles. I will be interested to see the longevity of those roofs. A couple to my eye at least are already in trouble four or so years into their life span, as the tiles are lifting and forming gaps. (I think it looks dilapidated, like an asphalt shingle roof that is so old that the shingles are wearing off.) I suspect that the roof structure wasn't strong enough and the beams are settling/warping under the new load, but however it is caused, there are now gaps for water, dust, and insects to get in.
All the best,
Peter
The guys today are straight from Guatemala. The one guy speaks a little English and said to get here they had some swimming to do.
I took one year of Spanish 50 years ago and thought I'd show off...
Don't do that!
It started off ok, I said "¿Buenos dias Como esta?"...they seemed happy...then I kicked it up a notch with "parece una mierda y bésame el culo". I'm not sure what that means but they started climbing down ladders!
I'm in the house...doors locked.
/ They started my new roof today... #47
All the best,
Peter
Part of the debate was that people pretty well know how tar paper will hold up under a metal roof, but there was some concern expressed that synthetic might not hold up to heat as well over the life span of the metal roof. The underlayment is going to get baked by heat transfer from a metal roof. There are also at least two different weights of tar paper as well.
I'm not familar with glass solar tiles.
/ They started my new roof today... #48
Yup...can't beat a metal roof!
I decided to go metal after my second Architect roof was failing. The third one was going to be my last!!!!! I research and decided to go with a company called EDCO. I used their "Arrowline Slate Steel Roofing". Another deciding factor was it's recommended to be put down over an existing roof with 30# felt paper. So there was no need to strip the old roof. Also the weight was a huge factor, only like 30ish pounds per box, and two boxes to a square. Saved a lot of labor and my "back"!! It definitely took more time to install, as it was my first metal roof, but well worth the effort.
/ They started my new roof today... #50
There are some older like 1900s homes here that have similar interlocking metal roofs like yours, except yours is much nicer. I suppose it's all the labor of fitting the pieces together that makes them relatively uncommon to see. But yours is very nice.
/ They started my new roof today... #51
They come in a variety of shapes, sizes and looks.
Some more integrated than others; note the interesting shingle and flashing gap on the top right below.
I think it has some advantages (more of the roof can be covered with solar cells, and glass is much stronger), and some disadvantages (most are being installed by solar companies, rather than roofing companies, and getting under the tiles to check wiring is a high labor task for most systems, though drones with FLIR help identify problem tiles/strings, and glass breaks rather than denting under say hail)
All the best,
Peter
/ They started my new roof today... #52
Yes...they are expensive to have installed. I believe mine ran me around $11K in materials, and many hours. Fortunately because I was able to go over the existing roof, I wasn't pressed for time. Would have been a different story if I had to strip it.
/ They started my new roof today... #54
Have any of you been following the "new" solar shingles (based on the perovskite solar cell)?
Supposed to be a lot more efficient.
The Google search linked indicates some researchers have them up to a 30yr life.
/ They started my new roof today... #55
Sorry, this hits a personal touchy subject for me of exaggerated claims by researchers and their PR teams.
Yes, Google will tell you lots of things, many of them true, but not all by long stick. Can we remind ourselves that some people have pretty odd ideas about whether the earth revolves around the sun, and the shape of the earth?
Let's just clarify that some researchers think on the basis of some extremely limited testing that their improvements to perovskite based cells may have increased longevity. All real world experience to date with perovskites suggests otherwise.
I had looked into the recent report, and it was a tiny number sample of lab made cells tested for a very short testing time. Frankly, I thought that their results did not come close to their claims. Their testing showed a not insignificant decay over a time scale of weeks. Given the chemistry, I personally think that perovskite cells have a long, long way to go before I would want to use them, and there is no guarantee that the fiddles to be applied in the future to achieve longevity won't cut into efficiency. Researchers often talk about a range of possible futures, and reporters tend to focus on an extreme case for click bait. I get it, it sells. However, it is neither good science nor good journalism.
The underlying interest in alternatives to silicon based solar cells arises from a desire to improve conversion efficiency, but given where the status quo is for the efficiency of silicon based solar cells, the cost of the other parts of a solar installation (panel production, permitting, labor to install, and ancillary hardware like the DC to AC inverters) already makes up so much of the cost, that for most applications, incremental solar cell efficiency improvements make next to no difference in the final cost of the power produced.
My $0.02 is keep your eye focused on MTBF, and $/kW installed. And by all means install solar if you haven't already.
All the best,
Peter
Husqvarna Riding mower (A56857)
Husqvarna Riding...
John Deere 4044M (A60462)
John Deere 4044M...
2018 CATERPILLAR 320 EXCAVATOR (A60429)
2018 CATERPILLAR...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
