Buying Advice Thinking about Yanmar 2210 but need some help
   / Thinking about Yanmar 2210 but need some help #31
I think (?) its universal that within the YM's, gray market will have round drawbar. And US YMs, flat bar.
Any more observations out there?
Never thought about that before but I checked out several models of greys and several of US and your thoughts seem to be correct. "As usual"
   / Thinking about Yanmar 2210 but need some help #32
As others have said, yes that's a drawbar. And yes it's round. Look up on Hoye. It's the same on my ym2000
   / Thinking about Yanmar 2210 but need some help #33
Like Winston had, I have a YM2002D. It has those exact same brackets under it with a round drawbar with a double hitch plate at the end.
   / Thinking about Yanmar 2210 but need some help #34
Thought I would swap the draw bar from my 1500 to the 2210 but the 1500 is square..
   / Thinking about Yanmar 2210 but need some help #37
My YM2610 from Fredricks didn't come with a drawbar. So, I popped the one off of my trade-in JD850 that is very rectangular and hard edged. Then weeks later, a neighbor from a good distance down the road actually had a YM gray drawbar, but no longer had the tractor. So, I now have both styles. The JD is really firm between the arms. It weights a bit more too, almost another 10-lbs. The flat area with the holes is also wider. A JD850 is a twin to the YM2500, green vs. red paint. The YM2500 is gear and the YM2610 is the Power-Shift version. Thus, all 3 machines are extremely closely matched as siblings.
I can snap a pix sometime with the 2 side-by-side to post here. Both fit the tractor.
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
Bucket (A55973)
Bucket (A55973)
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
