This day in 1997, of my house build
   / This day in 1997, of my house build #411
19970621 Saturday
Hutch helped
Installed last window on east side.
Windows and doors cost more than framing material.
More electrical connections
Cookout at the lot.
Looking down to basement where steps will go soon.
Is that young man you?
And still got that Home Depot nail apron.
No recorded work for the 23rd, but here is a look at pocket door framing for the office.
19970624 Tuesday
Electrical rough in inspection failed, a couple small issues.
They considered all of the dining area to be kitchen, had one circuit feeding outlet on other side of wall. Also couldn’t feed outside GFI from the inside GFI. Think they also didn’t like how I combined some grounds for multiple switch boxes.
   / This day in 1997, of my house build #416
I'm seeing in new construction that they are putting the GFCI outlets right next to the main breaker panel. Power comes from the breaker to the GFCI outlet, then to the bathrooms, kitchen, laundry and any other wet areas that need GFCI protection. I've seen as many as ten GFCI outlets next to the main panel box.
   / This day in 1997, of my house build #417
I've never saw that. Odd, but I guess it serves the purpose?
They would not have accepted that as they said kitchen circuit could not serve anything else. Outdoor gfi had to be on it’s own circuit, could not be on the kitchen gfi. They would not have let a kitchen circuit start in the basement.
My bathroom outlets are all on one gfi, located in basement bath, then goes up. Other outlets marked with gfi sticker.
I just fixed it to what they wanted, was minor work.
19970625 Wednesday
Dr appt, took off work early.
My roughin plumbing inspection passed.
Started to fix some of the electrical items.
19970626 Thursday
Took off work.
Front door due in at HD
Ordered basement steps
Redid electrical grounds and dining room outlet wiring that failed inspection.
1998 PETERBILT 377 (A58214)
1998 PETERBILT 377...
SKID STEER GRAPPLE BUCKET (A58214)
SKID STEER GRAPPLE...
INBOARD DRIVE (A58374)
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
