J_J
Super Star Member
- Joined
 - Sep 6, 2003
- Messages
 - 18,973
- Location
 - JACKSONVILLE, FL
- Tractor
 - Power-Trac 1445, KUBOTA B-9200HST
Eddie,
Nice job on the trailer. Just about 99% of all trailers have the angle on the back. you really did not have to take it off. As far as holding water, the water runs off through cracks, and doesn't hold water anymore than any other piece of angle on the trailer that touches wood. Two thirds of those boards will just slide in under the angle. We rounded off the corners of the others to help them slide in, and used the lift method for the last three. I believe the angle iron is there for support, not only to keep the boards in place, but for pulling things over the end without ripping out parts of the lumber. Lawn mower decks hang low and will catch on that open edge of the wood, As far as the sealing the deck, I have sealed many a deck with Thompson water seal. Most people don't put down enough. You need enough coats to let the sealant absorb and fill up the wood to a certain depth. Three or more coats may be required. Every year, add another coat.
When I was doing landscaping, I replaced a lot of tail light bulbs, due to vibration, pot holes, etc. After installing LED tail and stop lights, never had any more trouble. Initial expense is higher, but worth it.
