Tire chains-looking for opinions.
   / Tire chains-looking for opinions. #31
The thing about only front chains is that you lose traction when you start pushing snow because the from wheels tend to lift.
As opposed to the to wheels....:laughing:
   / Tire chains-looking for opinions. #32
I have front only chains for my NH TC 26 DA, and I use them only in the snow and ice. They make a huge difference in steering and traction. I have read all the debates about the use of front-only chains, but with the relatively small amount of use they get, I don't think they are going to cause any damage. There isn't a lot of clearance for chains on the rear, and I don't know if I could even get a set on them. The front chains are relatively easy to mount and remove. I discussed the use of front only chains with the dealer and they basically saw no problem with their use under these conditions. There is always enough snow and ice to allow for the tires to slip a little and they are never used on pavement.
If you were wanting to consider rear chains that fit low clearance applications, try what I have: Aquiline MPC chains. Here's some info: https://www.google.com/url?sa=t&rct...KvtGm77etELkwaOqd9TD6gA&bvm=bv.56988011,d.cWc
   / Tire chains-looking for opinions. #33
Very happy with the service/delivery/price from TireChains.com for my JD 2305 (rear) over 26x12.00-12 R4's.
Rear wheel spacers were a must for me to clear my optional deck lift hydralic line. Also bought the spring tensioners from the same vendor.
I got the 2 Link V-Bar. Just put them on for the first time a few weeks ago and I have to say they are extremely agressive as evidenced by the gouges in my concrete (shed floor and porch leading to drive) when turning. I am not concerned about the drive since it is gravel.
I will most likely find a coating to re-surface the storage area concrete in the spring but it is due for some TLC due to age/erosion anyway. The gouges are not that deep. I would not like to use wood long term due to pest issues (insect) as well as mold. Sacrificial OSB removed each spring for the small area I have to worry about might be my solution.
   / Tire chains-looking for opinions. #34
Sorry that should read front not "from".
I think what happens when you type fast and miss a letter is that the spell checker auto corrects and if you don't go back and read your post you get what the checker assumes you are typing.
   / Tire chains-looking for opinions. #35
I was just making lemonade from lemons ~ I can't type 'the' fast it always comes out teh, drives me nutz fixing it over and over- there should be a 'the' button on the keyboard!:thumbsup:
   / Tire chains-looking for opinions. #36
Consider some two inch treated planks. Should be mould/bug free.:D
   / Tire chains-looking for opinions. #37
I know what yuo mean!
   / Tire chains-looking for opinions. #38
Just bought 2 link chains for front and rear tires for my JD 3520 from tirechains.com. Debated the 4 link and vbar but in the end decided I needed the traction of 2 link without the perceived cement destruction of the vbar. I will eventually have a large cement pad in front of my garage (rock now) and didn't want the vbars to destroy it. Perhaps any chains will do damage, not sure. I have a large hill that I have slide 20 feet backwards two times this year already, and slipped off the drive into the ditch once. These chains will be put to the test soon... Snow expected tomorrow so will have to plow at least once before the chains arrive.
   / Tire chains-looking for opinions. #39
I don't know yet how well it is going to work, but based on suggestions from the group I purchased 4' by 6', 3/4" rubber stall mats from my local farm supply store (Big R). They sell them for $40 each. I used a saber saw to cut them in half length wise. I'm using them in my shop, under my 10,000 pound Kubota M9540. I have not needed to put my chains on yet, but I'm hoping that the mats will protect the concrete in my shop when I finally do.
   / Tire chains-looking for opinions. #40
That's a good idea... I was just at our farm store looking at deer fencing and saw a roll of that stuff and was thinking it would be nice in front of my work benches. I just got chains for my BX and could also use it for protection too. Thanks for sharing thoughts!
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
SCALES & PEA (A58374)
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
