Tire chains-looking for opinions.
   / Tire chains-looking for opinions. #51
On my 1100 foot driveway 500 ft is uphill. The first 200 ft of the hill is a 20 degree slope. My Kioti would not make it up in 4wd with the differential locked. Now with ice chains on it will allow me to plow up hill in 2wd with out locking the differential. The best money I have spent.
EHR, it sounds like you may live in an area with similar winter conditions to Minnesota. By ice chains do you mean vbar? I would love to not lock the differential when going up my big hill. I don't mind being in MFWD. I decided on 2 link, hope to receive them by early next week.
   / Tire chains-looking for opinions. #52
Now THERE is a realistic tractor plowing description. I couldn't really move on my hill without chains once the snow and ice started to build up (R4s). I got duo grips as they are in the middle between basic 4-link or 2-link ladders and overly aggressive v-bars for a driveway. The problem I have run into is that I did not realize how bad it was for other vehicles that were not 4wd/AWD for a while.... now I get it and have improved my plowing to compensate... On the plus side that could help keep out daughter's future BFs... :)
   / Tire chains-looking for opinions. #53
Getting out of the box a bit with the thinking of chains we have been studding treactor tires for a couple of years and having excellent success so far!
Depending on the type of tires many of them will accept screw in studs that we were using on the rubber tract snow groomers. The catch is short enough screw so they are not so long to puncture the tire. So that normally means no turfs for a total stud pattern but some might go on the edge. The ag and industrial tires have done well other then some in the center where we have cut the screws so not to go to deep.
The plusses are a smooth ride on a hard surface no up and down and being able to drive down the roads at speed in between driveways with just a bit of noise! They do wear some, although we have not gone to carbide head screws yet and most people just remove them during the summer.
   / Tire chains-looking for opinions. #54
I have 4 link ladder chains on my L4610 Kubota with filled rears and R4 tires. I easily climbed a fairly steep hill in 12" of snow. The rears would slip between sets of "ladders" until more chain got under the tire. I had no problems climbing the hill but I do think I would have had better/quicker traction with 2 link ladders. There was grass under the snow where I'm referring to.
My father came up behind me in his 1T diesel with very heavy plow on the front (raised) and with some momentum, made it only partially up the same hill. It took him 3 tries to get up it.
I was planning on buying ice chains (Aqualine Talon's) for my rears but I have to drive on the road to get between my house and his. I also wanted them for winter logging in snow as I know they'd be a lot better than the ladders. Since it isn't too easy for me to take chains on and off, I came up with a solution.
I am going to order the Aqualine Talon chains for my front tires. This way, I can keep the ladders on the rear for the entire winter, and when I'm going into the woods I can lift the front tires off the ground with the loader, and easily install the chains. While operating I'll keep it in 2WD but when the rears are slipping or not catching good enough, I'll put it in 4WD and have all the traction I'll need....hopefully.
I also have plenty of hills (not overly steep) at my place in NH that these will come in really handy for.
Does this sound like a good idea?
   / Tire chains-looking for opinions. #55
   / Tire chains-looking for opinions. #56
Sounds like a good plan to me - should give you selectable traction, and additional engine braking. I have regular chain (non V bar) Duo-Grips on my rears. They were a reasonable compromise between performance/cost/pavement preservation.
If you are in a situation where the front Vbar chains are delivering significantly more traction than the rear 4 links, you might want to keep in mind the power level you are operating at.
If you feel like adding individual connector chains between all your 4 links (to create an enhanced Duo-Grip layout), you will get some additional bite, and some added side slip (mild sidehills) traction.
Rgds, D.
   / Tire chains-looking for opinions. #57
Looks like I have about 1.25" clearance sidewall-to-fender with the rear tires on my M59.
Can someone confirm if a narrow chain like the Aquiline will work for this case? Or something
else? Thanks. The info online never seems to mention the actual clearance required.
   / Tire chains-looking for opinions. #58
I believe you may need at least 3" clearance for the Aquiline MPCs which I use. It could be less but probably not by much.
Here is an alternative, see link, that seems to be working great for a lot of guys with different model tractors for added traction withOUT chains or studs or (socks?:confused2:), whatever. YMMV.
http://www.tractorbynet.com/forums/snow-removal/193438-cutting-groving-siping-r-4-a.html
   / Tire chains-looking for opinions. #59
Depends how you bring stems to the landing. I pick mine up with the 3 point. I have 4 link ladders on the rear. This loads the rear of the tractor effectively enough where I do not need to engage 4wd in snow. Where 4wd comes in handy is completing the turn. With no weight, you have better traction in 4 wd. I did have front 2 link ladders on as well as the rears and in the snow, there is no stopping the tractor. In woods as opposed to ice, ladders are more than adequate. With jacking up the rear of the tractor, I have my rears on in 10 minutes from start to drive away chained.
   / Tire chains-looking for opinions. #60
Thanks for the additional info.
I almost always carry the logs/tops in my FEL grapple, so of course sometimes there is a fairly heavy load which will make the rears slightly less effective. However with filled rears there is still a good amount of weight back there.
The one thing I was a bit concerned about was hurting the pavement when I have to travel a couple hundred yards on it to get to one logging area. I called the tire chain sales company and they said that as long as I don't have an extremely heavy load in the FEL, and I keep it in 2wd only whenever on the pavement, it won't hurt the road at all. There is a chance I may notice a couple scratches on the pavement but I'm not worried about that.
For the most part, It will be very rare for me to travel on pavement with the Talon chains on my fronts, but is wanted to make sure that it would be okay once in a while as long as I'm careful.
I still haven't made the final commitment (I.e. Haven't actually purchased them yet) but I'm getting closer and closer. It's a lot of money to spend on chains so I'm going to think about it some more and go from there.
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
