yea, its almost as important to us all as the pallet issue
There used to be a video floating around where someone did 1 rear tire and then tried to drive in some snow. The non-grooved tire just spun and spun. Once he hit the diff lock and forced the engagement to the grooved tire the tractor moved forward. Seemed about as "scientific" as it gets.
ac
If proof of improvement to you is conditions where you don't even need 4wd now I believe your standards definitely need quantified.![]()
Im glad you were here to see my tractor perform! I guess I didn't notice you? You must be very educated on snow traction in Missourri
Sorry I'm not as smart as you?
My point was if grooving your tires enables you to perform your work now without 4wd, then the work you are performing is relatively easy. Not sure what your intelligence has to do with that.![]()
Where do you stand on pallets? Yeah or Nay?My point was if grooving your tires enables you to perform your work now without 4wd, then the work you are performing is relatively easy. Not sure what your intelligence has to do with that.![]()
