Tire grooving with my chainsaw
/ Tire grooving with my chainsaw
I for one would be very interested in hearing your analysis of your chainsaw grooved tires..
I will be more than happy to report my findings. No change in conditions here for the last few days. My driveway is a skating rink. I'm currently bleeding from my other hand after falling on said rink. Just a little scrape. The next time we get snow I'll fire up the NH and report back.
/ Tire grooving with my chainsaw #63
/ Tire grooving with my chainsaw #65
There used to be a video floating around where someone did 1 rear tire and then tried to drive in some snow. The non-grooved tire just spun and spun. Once he hit the diff lock and forced the engagement to the grooved tire the tractor moved forward. Seemed about as "scientific" as it gets.
ac
/ Tire grooving with my chainsaw #66
ac
That's a good idea. :thumbsup:
/ Tire grooving with my chainsaw #67
I'm not sure it really proves a lot other than two driven tires are better than one??
/ Tire grooving with my chainsaw #68
I still think the very first guy that did this had to be a full time skilled saw user and there had to be some sort of conversation that equated to "hold my beer and watch this". Maybe not those exact words and maybe there was no beer involved but this is how all great discoveries happen. :D
/ Tire grooving with my chainsaw #69
I think the point was that the non-grooved tire spun first. But then, depending on which side it was on that might be mechanically caused....... :)
/ Tire grooving with my chainsaw #70
More than the scientific crowd would want to admit for sure. :D
/ Tire grooving with my chainsaw #71
Do you also do stump carvings?, looks great!
/ Tire grooving with my chainsaw #72
Looking good on this site too, now we can go to the other site and start a thread "Best chain and chainsaw to groove tires.:D Couldn't find the chainsaw smiley.:mad:
/ Tire grooving with my chainsaw #74
/ Tire grooving with my chainsaw #75
If proof of improvement to you is conditions where you don't even need 4wd now I believe your standards definitely need quantified. :)
Im glad you were here to see my tractor perform! I guess I didn't notice you? You must be very educated on snow traction in Missourri :rolleyes:
Sorry I'm not as smart as you?
/ Tire grooving with my chainsaw #76
My point was if grooving your tires enables you to perform your work now without 4wd, then the work you are performing is relatively easy. Not sure what your intelligence has to do with that. :)
/ Tire grooving with my chainsaw #77
Obviously the work prior to grooving was very easy work, because the R4's couldn't do much work.
/ Tire grooving with my chainsaw #78
Where do you stand on pallets? Yeah or Nay?
/ Tire grooving with my chainsaw #79
I think I am pro pallet, but If I only knew why they were stacked against each other in fields, I could be more sure. :D If only the person who shall remain nameless had but brought this information to its logical conclusion we would all know the answer to that burning question, and could be sure of our stance in the important but unresolved pallet debate.
/ Tire grooving with my chainsaw #80
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
2021 VERMEER S925TX STAND ON SKIDSTEER (A60429)
2021 VERMEER...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
