TL90 or TN95
   / TL90 or TN95 #51
mark.r said:
From the NW website it looks like both the T4000 and T5000 share that TL cab.
It may look that way to the untrained eye;) but the T4000/TN-A cab is a straddle mount cab and is smaller then the T5000/TL-A cab.
An interesting note for some not use to the TN line, the TN series actually has 3 different cabs. The standard TN cab, the narrow TN-F cab and the ultra narrow TN-V cab.
   / TL90 or TN95 #52
Ahhh, yes the untrained eye.;) I forgot about the straddle mount vs. the flat deck. I really can't wait to see a T4000 vs. T5000 vs. T6000 on the same lot in real life (specifically the 5000 vs. 60000). I am having a hard time picturing them in my head. It all gets lost in the nomenclature.
   / TL90 or TN95 #53
Yeah the TN cabs are nothing like the other cabs, I can't imagine how tight a TN ultra narrow cab is, I find the regular TN cabs are small like my Kubota's.
   / TL90 or TN95 #54
They are very cozy. The TN-F cab isn't too bad but the TN-V cab has everything so compact you kind of twist yourself in to the cab and sit down. It is comfortable but you do not have the room to stretch out like you would on the standard TN cab. The TN-F cab is around 8" wider then the TN-V cab
Here is a TN-VA cab from the back
Here is a TN-FA cab from the back
   / TL90 or TN95 #55
Thats a lot of tractor in a not very wide package. Would make a good sidewalk plow!
   / TL90 or TN95 #56
Not to change the subject but whats the drilling implement in the first picture?
   / TL90 or TN95 #57
The augers don't drill, I believe its for doing something to grapes, picking maybe.
   / TL90 or TN95 #58
I have never used one before to be positive and have only seen them being used from a distance here but it looks like a mechanical pruner. But it could be a groomer also.
   / TL90 or TN95 #59
These tractors are generally used on 300 and 400 gallon air blast sprayers so the power is needed for pto work.
   / TL90 or TN95 #60
I'm not sure where I saw it but the standard TN cab does have a training seat option. It may be only in Europe.
Andy
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
LOT OF ROUND ROD (A58374)
LOT OF ROUND ROD...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A55973)
2006 Ford F-750...
2013 KUBOTA SVL90-2 SKID STEER (A52709)
2013 KUBOTA...
2019 Ford F-250 4x4 Crew Cab Roya Service Truck (A55973)
2019 Ford F-250...
