To Hydro or not to Hydro??..What is the answer?
   / To Hydro or not to Hydro??..What is the answer? #11
Okay, my current tractor is not a Deere, but after having the Deere PowerReverser on my previous tractor, I saw no need for a hydo. Well, I'm converted. The learning curve is short. The questions about durability seem to be unfounded. I've never heard of a hydro going down. For the "novice" and experienced alike, there is no comparison. My wife never got used to the gear drive with the PowerReverser. She could drive the hydro in 2 minutes.
   / To Hydro or not to Hydro??..What is the answer? #12
another vote for HYDRO have not run across a case where i wished i had a geared tractor. but all people have different needs and preferences, But i LOVE MY HYDRO, AND would have no other. and the cruise control(for want of a better term) works quite well, although i have not used it much.
   / To Hydro or not to Hydro??..What is the answer? #13
Love my ehydro with cruise
Sometimes I dont even use the pedals
use the button to slow it down / turn / speed backup
without the pedal
You can also set max speed so that if you are using the pedal you can just push all the way / you do not have to try and hold speed - the cruise just lets you speed up to the previously *** max speed...
4720
tom
   / To Hydro or not to Hydro??..What is the answer? #14
Yet ANOTHER vote to go with the hydro....I too was concerned about reliabilty but after reading the multitude of posts on TBN my worries were put to rest. You cannot beat the ease of operation a hydro provides, especially for loader work. What I really appreciate about having the E-hydro on my 4210 is the fact ANYONE can operate it....my brother was visiting last month and he has never driven a tractor in his life, after a minute's instruction he was seated on my JD and moving 1200 pounds of fill dirt for me. Any extra cost paid up front for the hydro will be recovered at resale time, and I personally think it's an option that will enable you to resell the tractor more easily, to a broader range of buyers.
And the cruise control is just more icing on the cake. I didn't think I would use it very often, but I was wrong.
Just my nickle's worth.
   / To Hydro or not to Hydro??..What is the answer? #15
Another HYDRO vote: 160 hours and I love its ease of use.
   / To Hydro or not to Hydro??..What is the answer? #16
The wife and kid can also use my 4310 eHydro without a problem. That's good in case I fall off and the darn thing runs over me.
   / To Hydro or not to Hydro??..What is the answer? #17
There is a seatbelt on it you know.......
   / To Hydro or not to Hydro??..What is the answer? #18
I wanted the hydro on a 4120 but jd says they might overheat if I pull a disc harrow. Any truth to that??
Thanks
   / To Hydro or not to Hydro??..What is the answer? #19
Several dealers I spoke to and other sources have expressed the caution that continuous heavy draft loads (as in pulling a plow, disk, or cultivator) will overheat and damage a hydro transmission.
Actually when I first talked to the dealer I ended up buying from - he asked what my intended tractor uses were. As I went down the list - and before I ever expressed a preference in tranny types - as soon as I said 'some plowing' he said "then you don't want a hydro transmission, you'll burn it up".
What nobody has ever been able to articulate is exactly how much heavy draft duty it takes to put you into that kind of category. I have a hunch that most CUT owners - plowing up a garden or even a couple of acres - or pulling a modest disk - would be unlikely to push their tractors to the kind of serious draft workload (in effort or duration) they are talking about.
   / To Hydro or not to Hydro??..What is the answer? #20
I am with Timb, an honest ssessment of hydro from a man who is not a fan!
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
