TYMinColton
- Joined
- Mar 18, 2008
- Messages
- 274
- Location
- Colton, OR
- Tractor
- 2008 TYM T273 w/ FEL - 100 hrs, 1962ish Ford 881D project - hrs unknown
Worth a try at least. And no, at this point the added cost isn't worth it. If I can get her running and she's good for 1000 hrs that'd be a victory.OOR - I think he means Out Of Round. When cylinders wear they get larger at the top and also egg shaped.
Those may be on the edge of nasty, but for 20-40 bucks you could get a hone and try to fix them up and see what you get. That would only cost you a small amount of time and money.
I blew the big bucks on mine as there were some serious gouges in one cylinder where a broken ring had wedged between the piston and wall after some nimrod had used ether incorrectly to start it. Grrrrr. 8500 hours and the cylinders were still in spec for stock pistons, except for that gouge. Naturally, some smuck had hit the crank too. And thats with one rod 91 grams lighter than the rest!
Short story is you can probably get away with honing, ringing and replace bearings. Full rebuild is better and will last longer, but is the added cost worth it?
jb
Sounds like you got a really raw deal with your engine. There must a be a pretty large graveyard out there for the all of the perfectly good pistons that go homeless. Looking through many a TBN post, I suspect that a lot of folks may be suffering a similar fate. Then again, maybe they do know what they're doing.
I tried to get my hands on a 4" ball hone on e-scam (funny!) today, but no such luck. I might just drop the block off at the end of the week and having her sunnen honed. I'll probably break about even, and hopefully will benefit from having someone who (a) knows what they're doing, and (b) has equipment that should let me set a maximum depth of cut. I'll just do the cleanup myself.
Pete
