Tough choice, B7500 or B2410?
   / Tough choice, B7500 or B2410? #21
I've got a link below with some pricing info that might be useful. I traded up from a B2100 (which is basically a B7500 with position control) to a B2410. I made the trade to so that I could keep position control and so that could upgrade from gear to hydrostatic transmission.The extra power didn't make much of a difference for my uses, but the extra weight now that I've got a FEL and I keep the MMM on makes a huge difference when I use the box blade.Will
   / Tough choice, B7500 or B2410? #22
Dave that sounds like a good deal to me. I have a similar setup and I run a Woods RD 6000 it does a great job. The B-7500 is a very capable machine, you will not be dissapointed, have fun and be safe./w3tcompact/icons/wink.gif
   / Tough choice, B7500 or B2410? #23
I think reading this forum over the last few months has considerably added to my confusion. I have no idea what to do. Just bought a place w/3 acres that will need some dirt & rocks moved around. A lot of watermelon size rocks in the soil. I will also be digging some fence post holes, and need to clean up all the brushy crap/vines along a fence and an old stone wall. The grass is pasture grass. Pretty tough, but I see my neighbors using lawn tractors, so must not be too bad. Also want to be able to move snow on my 150' driveway. It sounds like the BX is the best grass cutter, but I still don't understand why. I hate the fact that if I wanted to buy a BH later, it can't be mounted on the BX also. No...for the price of the BX22, I think I should just get a bigger B series. I also hate to be underpowered. That's why I was considering the 7500 or 2410, but TresCrows has me concerned about the mowing ability. Is the MMM working any better on the 2410?
So at this point, it's either the BX2200, B7500 or B2410. MMM, FEL on whichever.
Also, we would like to end up in a place w/more property in a few years, or buy more where we are at. So that should be in my decision making.
I also have this thing with not wanting to be driving around a MONSTER tractor for my 3 acre lot when my neighbors are using garden/lawn tractors.
What does everyone think?
   / Tough choice, B7500 or B2410? #24
Hey neighbor!
Although this is a much discussed topic, I'll put in my two cents.
I have the same size lot as you. Had the BX been around three years ago when I bought my B2400, I would probably looked at that very closely. The B2400 is a bit overkill for what I have used it for so far, but who knows what projects are ahead. I'm currently shopping around for a loader, so I expect it to see much more use than the present mowing and snow plowing (not an issue this year). Most of the lots in my area are 2-10 acres. Two neighbors bought ZTRs last year. There's a BX, and a couple of 2150s all with loaders down the road. I don't think you need to worry about looking out of place.
Of course, any of the models you mention will fit the bill nicely. Since you're looking to buy more property in the future, you might want to lean toward the larger units.
   / Tough choice, B7500 or B2410? #25
Gomez,
I guess we are practically neighbors. We are actually up in Haycock. Anyway, thanks for the advice. I guess there are really no easy answers.
How do you like the MMM on yours? What condition is your lawn. My is basically a field. Kind of bumpy, but not too bad.
Thanks.
   / Tough choice, B7500 or B2410? #26
Haycock, I have a few of cousins up there. I remember when they we putting up their houses, nothing but rocks. Had to blast for the foundations.
The MMM works great for me. My lawn is pretty smooth, although I've cut some brush with it. The blades are substantial, so I wasn't too worried about the heavy brush. Of course, the concrete property line marker put up a fight./w3tcompact/icons/tongue.gif Just keep the gage wheels well lubed.
Good luck.
   / Tough choice, B7500 or B2410? #27
Yes. A lot of rock. They had to blast our cellar out as well.
   / Tough choice, B7500 or B2410? #28
Well, get the tractor that makes you happy, consider also if your field is bumpy the BX suspended deck rides on the tractor wheels and the 2410/7500 deck rides with it's weight down on those tiny little castors. The BX deck glides over the ground whereas the deck on the 7500/2410 clangs and bounces along over every little bump. Those little wheels leave worse ruts than the tractor does especially when turning. A few other brave souls have verified this and posted it. I am beginning to figure my 2410 MMM out and like I have said it is not totally terrible but it is nothing like the BX suspended MMM. Some JD tractors have suspended units--check one for JD! J
Also, depending on your lot, a rear mounted deck may be better than the MMM. Definetely easy on and off.
   / Tough choice, B7500 or B2410? #30
For the folks in a quandry over the bx/75/24 sizes, I have been thinking of the uses for position control. If you have a gravel driveway to maintain, or if you plan to use a box blade for ground leveling, or if you have a landscape rake and NO gauge wheels, position control is a MUST! I just re-surfaced my 800 foot driveway with crusher run that was tailgate spread (although not entirely, since he had to lower the bed to miss some overhead wires in spots). The secret to a smooth surface is many passes just skimming off the top. THis is best done with a box blade at the appropriate angle AND height. Using position control helped me immensly.
Another idea I just had about position control is for mowing over severely bumpy gound. Although the B series mower decks roll on the ground, the hydraulics can suspend them easiliy, with no damage to the system. THe concern is evenness of cut, not machine damage. Here, you could find the right position to raise the deck to over the bumpy stuff, get a pretty even cut, and avoid the dreaded castor ruts from sharp turns/soft ground. I vote for position control unless you have a paved driveway and a smoothly finished, manicured lawn. Then, I vote for the larger machines just on general principle/w3tcompact/icons/wink.gif
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50322)
2017 Taylor-Dunn...
PT Canal Pump (A50121)
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Club Car Carryall 500 (A50121)
Club Car Carryall...
