Towing my tractor with the canopy?
   / Towing my tractor with the canopy? #1
lug nut
Jackson,TN
New Holland TC-55 DA
I installed the canopy on my tractor today, and I noticed something kinda scary while I was hauling it home. I got on the interstate and started to get up to speed. I looked back at my tractor and saw that the canopy was moving a good bit up and down due to the wind. I got off at the next exit and took the scenic route home.
Am I just being paronoid, or will my canopy eventually crack and/or break off all together?:eek:
   / Towing my tractor with the canopy? #2
I don't have a canopy but I'd say that if it looks like smoke and smells like smoke, the top may be in jeopardy. I say this relative to towing a boat with a cover. Not a good idea at all. I also tow pontoon boats with hard tops. They are a bit larger and have more supports, but I hate to tow one at interstate speeds for the same concerns.
   / Towing my tractor with the canopy? #3
The best way to haul your tractor with a canopy, is to haul it backwards on the trailer. Little risk of damage this way. (This is assuming your canopy is fastened to your ROPS and most of the canopy faces forward.)
   / Towing my tractor with the canopy? #4
I tow all the time with mine and have not damaged either tractor.
They are the metal ones with a metal frame. Hopes this helps.
Sully
I forgot to mention that my canopy is fiberglass and is only attatched to the ROPS. I thought about fabbing some supports for the front of the canopy, not only to help while towing but also with tree limbs snagging it.
   / Towing my tractor with the canopy? #6
Even though mine is removable, some times I get lazy when going from job to job, so now I just throw one of my ratchet straps over it and snug it down to the tractor, keeps it from flopping up and down.
   / Towing my tractor with the canopy? #7
Mine is fiberglass. When I trailer it, I run two of the small ratchet straps over it. I hook one end of each one at the back edge of the canopy toward each outside edge, run them over the top, then hook the other ends on the steering wheel, and just snug them a little. That way it can't get air under it and rise up into the main airstream and rip off. Works fine.
   / Towing my tractor with the canopy? #8
I always tow my tractor with it on the trailer backwards. It helps my canopoy and levels my trailer out this way a little better.
Chris
   / Towing my tractor with the canopy? #9
I haven't towed my tractor since I put the fiberglass canopy on (actually I've never towed it:eek: ), but last year after I installed it I had to have the dealer pick it up. The dealer just loaded it on the truck forward and didn't do anything special. Just hauled it. I'm assuming they traveled between 55 & 60 with it. Probably 30 - 40 miles to the dealer. I've not noticed any problems with it since the hauling.
   / Towing my tractor with the canopy? #10
My B2400 has a cannopy and it has a warning label that says to trailer it backwards. that will solve your problems.
Ian
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
John Deere 6300 (A60462)
John Deere 6300...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
