Tractor purchasing advice
/ Tractor purchasing advice #1
Legdoc
I am planning to purchase a new tractor in the 95-110 Hp. range. This is to compliment and possibly replace my Kubota M6800 which has been excellent but is open cab and somewhat underpowered. The new machine duties are to manage 200-275 acres. This includes 15' batwing shredding, handling large round bales, discing, renovating, post holes, herbicide spraying and possibly cutting and bale of hay. I want a cab with A/C due to bees and allergies. The choice is either Kubota or John Deere. I have looked at a Kubota M9540 and Kubota M108 but I really want to stay away from all the electronics on the CRD M108. I am open to JD but I am not familiar with JD. Any suggestions are appreciated.
Legdoc
/ Tractor purchasing advice #2
I cannot give specifics on that large of JD, but I have a 56 HP model that I am very happy to have it is well built and performs all tasks that I have asked it to do.
I don't know the area of the country you live in but I would suspect that if you looked around your area on the larger farms you would find many JD's of that size. Ask the farmer who owns one. I'll bet they researched their purchase before buying. Those machines are not cheap.
I know in North Texas I see many more JD's of that size and larger than most other brands.
Good luck on your search, and the dealer will make the difference on a good purchase and a great purchase.
Thank you for the reply. I am in S Texas and have a excellent relationship with the Kubota Dealer. They are the type people that you can go to the owner with a question or walk into the shop and get a straight answer anytime. I expect the purchase with quick attatch on the FEL to be about 40K.
Any other suggestions are appreciated as I am still leaning toward the M9540.
Legdoc
/ Tractor purchasing advice #4
One of the best bargains on the market in that range is the JD 5603. While it has a lot of amenities, it is not their premium tractor. Essentially it is a cab model with Power Reverser, 4cylinder turbo, 4WD and has economy PTO. This allows you to run the engine at about 60% rpm to spin the pto at 540. This saves fuel on lower demand implements. I think you can get one fairly loaded out with FEL for your price range.
John Deere Ag - New Equipment Features for 5603 Tractor (99 hp)
I hear the Kubota dealer in Victoria sometimes offers good deals. Are you near there?
/ Tractor purchasing advice #5
Check out a CNH TS110
Many of the road crews for county maintenance are switching to those as they slowly get rid of their fleet of NH 7610s that they have been running for the last few years.
soundguy
/ Tractor purchasing advice #6
I have a 6430 Deere that's used primarily to pull a 15' batwing used in a mowing business I own. More than adaquate for the chore. (95pto hp) I don't normally advocate the "new breed" of tractors. I'm more inclined to like the older ones fron the mid 80's on back. But this Deere is something to behold. Easy on fuel, great power, very reliable. We logged over 1400 hours in one year with NO mechanical issues. When the weather forced us, it ran 2 shifts a day, 7 days a week.
/ Tractor purchasing advice #7
If you want something cheaper than a JD check out the MF 596. It is a solid tractor without the pushbutton/power reverser tranny. It handles a 15' batwing with ease. If you want that style trans try the MF 5455.
I also like the Kubota 108. I almost bought an MX 125 instead of the MF.
/ Tractor purchasing advice #8
I looked at the 5603 specs and it sounds great. It is the only Deere in the 5000 series that is NOT made in India (made in Augusta, Georgia) so if the price is right, it would be be a good one.....
I may look at the JD 5603 since it is domestic. We have a JD, NH and Kubota Dealer here. Kyle I am in Victoria. The Kubota Dealer you speak of is Victoria Oliver Co. They are ther best people you will find! I want to stick with a brand with a local dealer although I realize there are other good brands. I appreciate the advise given.
Legdoc
/ Tractor purchasing advice #10
Legdoc, I grew up in Victoria. Now live in Giddings and commute to Austin.
The last thing I want to do is start a brand war, so I'll recommend you test drive and ask plenty of questions. Don't sweat over trivial stuff like if one tractor's FEL says it may lift 150 lbs more than the other brand. Weight is good for ground engagement but not necesarily needed for hay production. 4WD tractors can do more with less weight, you can fill up your FEL's bucket with dirt if you need some weight. 250 acres is a lot. You may end up wishing you had 2 tractors. Use the smaller one to rake and spray.
Here are a few things about the Deere I can tell you.
The Deere are assembled in Georgia from parts made around the world. The 4cyl engine is one of the most durable you can buy in any tractor. Deere has a parts system that is one of the best in the world. You can check your dealer's (and surrounding dealers') stock, get pricing, order whatever you want and see exploded diagrams of parts. All while sitting in your skivvies at home on the net. Deere holds it value as good as any. On top of that, I can tell you that a midsize utility cab model deere with 4wd will hold its value better than almost any other model deere offers.
If you want to shop around besides Victoria, call Shawn at Jaeger's in Shiner and tell him Kyle from Giddings recommended calling him. I don't have any experience with the bigger Kubota's.
/ Tractor purchasing advice #11
I also prefer the older ones.. in the ford/nh range I like the boxy thousand series with the 8spds.
the trans have poor speed ranges IMHO.. but are virtually bulletproof. hyd pump capacity varies by model.. from anemic to adequate.. but otherwise good machines. i love mowing on my 5000 and 7610s. Mowed with a 4630 with 8spd the other day.. felt nearly as good as my 5000 except it was closer to the dust!
soundguy
/ Tractor purchasing advice #12
I traded in my JD4430 for a JD5603 and I can say that I am very happy. I pull a 10' rotary mower and I have no problems. I have not baled with it so I can not comment there. I did look at Kubota but I felt the JD cab was roomier and quietier than the Kubota. I love the power reserver. Another thing I noticed was the weight difference, the JD is about 1500lbs heavier and you could feel that when running the two different machines. I bought my 5603 for 37k that is with dual hydualics in the rear, radio, no FEL. Both machines are good I just feel the JD is a little bit better in construction. I also love JD service and parts.
/ Tractor purchasing advice #13
For what you are wanting to do I would follow Farmwithjunk's suggestion of the 6430 over the 5603. The 6430 is around 1800 pounds heavier and if you plan on baling the heavier tractor will work better for it. The 5603 is a good size for general chore work and such but it is a small utility pushing out large horses.
Now if it was me I would look at the New Holland T6000 (old name is the TS-A). If you plan on spending a lot of time in the tractor the cab on the T6000 can not be beat. You can also look at the New Holland TD-D if you want to save money. It is a nice tractor without all the frills.
Try them all (and not just in the dealers parking lot) doing what you want them to do and see how you like the tractor and the dealer and decide from there. This class of tractor is fairly competitive and they all make nice tractors in this range.
/ Tractor purchasing advice #14
Actually its only the 5XX3 series equipment that is made in India...less of course the 5603...
All of the other 5XX5 and 5x25 series are all made in GA....
