TRACTOR WEIGHTS
/ TRACTOR WEIGHTS #41
Don't forget that Rimguard weighs about 3 pounds more per gallon. Costs more, but weighs more.
/ TRACTOR WEIGHTS #42
The shop where I work has a job where we use 3/4" plate steel and burn "windows" in it. I purchased some of the cutouts and had them machined by the guy on the machine next to mine. First I made a bracket that I slide on to the front bumper then just hang the weights on it. I have 10 of them and I think they weigh 25# each. I have a B7510 21hp 4x4 hsd they work great to hold the front down! :thumbsup:
/ TRACTOR WEIGHTS #43
must be nice..
soundguy
/ TRACTOR WEIGHTS #45
scrap prices no less.. :)
/ TRACTOR WEIGHTS #47
brag brag brag.. :)
good for you though!
soundguy
/ TRACTOR WEIGHTS #49
naw.. good for you. I like it when i find a deal.. I like it when my friends and aquaintences find a deal too.
soundguy
/ TRACTOR WEIGHTS #50
we need a "LIKE" button on here like Facebook does!! :thumbsup:
/ TRACTOR WEIGHTS #51
Ok here i go, i finially got around to posting the picture of my tractor weights. The bar on the bottom is solid 3" steel bar stock about 40 something inches wide, the top pipe is about 3" ID and filled with lead. Both welded togeather tip the scales somewhere around 175 lbs. Thats about a 6ft hunk of Rail hanging off the back back there my guess on it is just shy of 400lbs?
/ TRACTOR WEIGHTS #52
I have a YM2000 and I need to know where I can get Weights for the rear wheels and front - end of my tractor.
/ TRACTOR WEIGHTS
If I had the time I would have fabricated some as some on here have done------But I had not the time so I bought some from my dealer.
I think your YM dealer can get them for you----but be prepared---they be high $$$$$:smiley_aafz:
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
500BBL WHEELED FRAC TANK (A67714)
500BBL WHEELED...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
