Trailer shaking at 60MPH
   / Trailer shaking at 60MPH #11
I’d check tires for balancing first and if they balance easily then I’d move to checking axle alignment and wheel bearings.
-Chris
   / Trailer shaking at 60MPH #12
I have a shake at 30-35 on my fairly new Kaufman
Otherwise smooth as glass.
   / Trailer shaking at 60MPH #13
Tire balance is difficult on a trailer because you really can not set camber / toe accurately on a trailer, when you have a tire that is causing vibration and this is dependent on the fact that you have determined that there was no movement / damage done to the axle alignment at blow out, that it is most likely the new tire - one of the easiest things you can do is re-align the tire on the rim, mark the tire rim location with tire chalk, rotate the tire to a different mounting position - for balance I use / toss in tire beads, they seem to work better as run out can change, the beads will change placement, they work very well on trailers...
   / Trailer shaking at 60MPH #14
Thanks!
That sounds like a GREAT way to solve a nagging problem!
Yep, before you take them off shake them and spin them to make sure nothing is bent or loose.
Aaron Z
Those are the back tires. Everything was tight when I shook them on the trailer.
   / Trailer shaking at 60MPH #18
   / Trailer shaking at 60MPH #20
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
Cushman Cart (A55853)
2019 Ford F350 (A55973)
2019 Ford F350...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
