FTG-05
Elite Member
- Joined
- Jan 7, 2011
- Messages
- 2,593
- Location
- TN
- Tractor
- Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
Maybe I am over thinking? Antifreeze is nasty, doesn't dry or evaporate. It will coat the tire, wheel and valve stem. Anytime you check the air, I would think a spec of antifreeze would get in the gauge. You would also need to wash the tire and dry it, for a patch to stick.
Yea, you're overthinking it. I have antifreeze in all my tires, trucks and trailers, as dynamic balancers. I've had a couple of them patched; it's never been problem; it's a couple ounces for crying out loud, not a toxic waste dump. It's inside a tire, how many times do you have to deal with the inside of a tire? Let's see: a truck, Pathfinder, trailer, ZTR, tractor, RTV tires - in 7 years, maybe two trips to the tire dealer for a tire patch. BFD.
Checking air pressure: AF drops to the bottom due to gravity (which never fails); the amount getting into a pressure gauge is minuscule. I've checked my tractor and ZTR tire pressures all the time - which are 75-80% filled for ballast purposes - still no big deal.
Nasty? Use RV antifreeze, it's potable water compatible.
