Trying to decide Kubota BX25 or 1025R
   / Trying to decide Kubota BX25 or 1025R #41
I did a lot of comparisons; data sheets, test drives, digging holes on dealer properties, etc. BX25D-1 vs 1025R is 6 vs 1/2 dozen. You just have to decide what is most important, to you.
I ended up with the Kubota BX25D, a 60" MMM, and a 60" Land Pride rear blade (cost me $48). The John Deere was really its only contender. The biggest problem with the 1025R TLB was the price ($5,000 more than I paid for BX). The second biggest was the single function hydraulics. The third was the seat.
The $5,000 pretty well explains itself. The single function hydraulics are a big deal, to me. Yes, the JD specs higher, on paper, but at the cost of going two directions, at once. I was able to pop a >4" root with the BX25D backhoe, but had to torque it two ways. I doubt the extra umph of the JD would have been enough. The BX25D seat is better than the 1025R seat, for my butt. The JD bounced too much.
Of course, the JD has some great advantages, too. From the seat ergonomics are superior on the JD, without a doubt. The location of the loader controller, auxiliary plug, and the addition of a storage compartment and tilt steering wheel trump the BX by a long shot. The bucket level indicator of the JD is functional, the BX is stupid (or I am, but no one can really seem to make it work); actually, the JD buckets are more functional, in pretty much every way: the flat top beats the rolled top, so much easier to weld on hooks or accessories.
Removing the JD FEL is cake. The BX required more steps, but is not taxing or labor intensive. Obvious benefit to JD, but not a game changer, to me. I prefer where the FEL hydraulic hookups are, on the BX, as they seem safer.
The BX cooling fan is often shown as a weak link. It's not a plus, as the transmission cooler on the JD is superior, unless it has an issue. A new fan is only $20, but a huge PITA to replace. The tranny cooler would be big money, and a PITA; though, it is unlikely to be damaged.
The hood on the JD is one piece and moves enough for service. The BX shroud has to be moved forward, after taking off the front guard. It's a few extra steps and the one piece would be nice to have.
They are more alike, or personal preference, than anything:
Pedals: The JD is more efficient, but I've never had a problem with he heel-toe design. There have been times, working around delicate things, where I preferred the heel-toe, so I didn't accidentally go the wrong direction. This is my first tractor and heel-toe is more idiot-proof.
Mower: (comparing 60") Both cut great. The BX rides higher, which is a plus. It's safer for it and you can cut up to 6", if you need to. The JD's drive over is infinitely better than the BX drive over. JD has a cool Autoconnect, but it's only cool when it works. Crawling under the tractor to connect the mid-PTO sucks, big ones. Having problems with the JD Autoconnect would probably suck bigger ones, but it's not likely you'll have a problem, either.
Size: It's so close, it probably doesn't matter. I know I got a job with my BX the JD would have been too wide for, so that's a plus. The JD is wider, so it's more stable, that's a plus. You can buy spacers for the BX, so it can be even, but you have to factor that cost into the $5K savings. The BX has higher ground clearance, according to Kubota, but the JD lifts more, with a comparable footprint.
Implements: JD and Kubota offer a fair amount of accessories and implements made for these tractors. JD has Frontier and Kubota has a dealer arrangement with Land Pride. I don't know much about Frontier, other than to say they appear to be quality and expensive. The Land Pride stuff is quality and expensive. It is made in Salina, KS, wich is cool.
I'm sure there's more, but I have to get the kid to school. In the end, I doubt you'll find too many jobs one can do that the other can't. Both run out of traction and weight before horsepower. Both are much more capable than they look. Here's a review I did of two used units, when I was shopping, keep in mind this was an older BX25, not the one with the nicer seat and dash: http://www.tractorbynet.com/forums/buying-pricing-comparisons/328518-2012-kubota-bx25-tlb-vs.html
For the most part, these comparisons ring true on the current models.
As far as the Massey Fergusons, I wasn't able to find a newer one to look at (with the TLB) with 200 miles of my house, in the two years I looked. There is one in town, but it's the first model they made, in the subcompact TLB and the guy has TRASHED it. I don't think it's a reflection of the machine, more the man.
The MF seems to offer a lot, on paper. I did sit on the GC1715, but didn't get to run it, at all. I find the MF GC line to be a strange middle ground, even blend of the benefits the JD and BX compete over. To get a MF, with the same setup I got in the BX was going to cost around $2,000 more. If I could have actually used one, to try out, I think it would have been a very tough choice between it and the BX.
No matter what you read, there's a lot of fanboys.
   / Trying to decide Kubota BX25 or 1025R #42
I did a lot of comparisons; data sheets, test drives, digging holes on dealer properties, etc. BX25D-1 vs 1025R is 6 vs 1/2 dozen. You just have to decide what is most important, to you. I ended up with the Kubota BX25D, a 60" MMM, and a 60" Land Pride rear blade (cost me $48). The John Deere was really its only contender. The biggest problem with the 1025R TLB was the price ($5,000 more than I paid for BX). The second biggest was the single function hydraulics. The third was the seat. The $5,000 pretty well explains itself. The single function hydraulics are a big deal, to me. Yes, the JD specs higher, on paper, but at the cost of going two directions, at once. I was able to pop a >4" root with the BX25D backhoe, but had to torque it two ways. I doubt the extra umph of the JD would have been enough. The BX25D seat is better than the 1025R seat, for my butt. The JD bounced too much. Of course, the JD has some great advantages, too. From the seat ergonomics are superior on the JD, without a doubt. The location of the loader controller, auxiliary plug, and the addition of a storage compartment and tilt steering wheel trump the BX by a long shot. The bucket level indicator of the JD is functional, the BX is stupid (or I am, but no one can really seem to make it work); actually, the JD buckets are more functional, in pretty much every way: the flat top beats the rolled top, so much easier to weld on hooks or accessories. Removing the JD FEL is cake. The BX required more steps, but is not taxing or labor intensive. Obvious benefit to JD, but not a game changer, to me. I prefer where the FEL hydraulic hookups are, on the BX, as they seem safer. The BX cooling fan is often shown as a weak link. It's not a plus, as the transmission cooler on the JD is superior, unless it has an issue. A new fan is only $20, but a huge PITA to replace. The tranny cooler would be big money, and a PITA; though, it is unlikely to be damaged. The hood on the JD is one piece and moves enough for service. The BX shroud has to be moved forward, after taking off the front guard. It's a few extra steps and the one piece would be nice to have. They are more alike, or personal preference, than anything: Pedals: The JD is more efficient, but I've never had a problem with he heel-toe design. There have been times, working around delicate things, where I preferred the heel-toe, so I didn't accidentally go the wrong direction. This is my first tractor and heel-toe is more idiot-proof. Mower: (comparing 60") Both cut great. The BX rides higher, which is a plus. It's safer for it and you can cut up to 6", if you need to. The JD's drive over is infinitely better than the BX drive over. JD has a cool Autoconnect, but it's only cool when it works. Crawling under the tractor to connect the mid-PTO sucks, big ones. Having problems with the JD Autoconnect would probably suck bigger ones, but it's not likely you'll have a problem, either. Size: It's so close, it probably doesn't matter. I know I got a job with my BX the JD would have been too wide for, so that's a plus. The JD is wider, so it's more stable, that's a plus. You can buy spacers for the BX, so it can be even, but you have to factor that cost into the $5K savings. The BX has higher ground clearance, according to Kubota, but the JD lifts more, with a comparable footprint. Implements: JD and Kubota offer a fair amount of accessories and implements made for these tractors. JD has Frontier and Kubota has a dealer arrangement with Land Pride. I don't know much about Frontier, other than to say they appear to be quality and expensive. The Land Pride stuff is quality and expensive. It is made in Salina, KS, wich is cool. I'm sure there's more, but I have to get the kid to school. In the end, I doubt you'll find too many jobs one can do that the other can't. Both run out of traction and weight before horsepower. Both are much more capable than they look. Here's a review I did of two used units, when I was shopping, keep in mind this was an older BX25, not the one with the nicer seat and dash: http://www.tractorbynet.com/forums/buying-pricing-comparisons/328518-2012-kubota-bx25-tlb-vs.html For the most part, these comparisons ring true on the current models. As far as the Massey Fergusons, I wasn't able to find a newer one to look at (with the TLB) with 200 miles of my house, in the two years I looked. There is one in town, but it's the first model they made, in the subcompact TLB and the guy has TRASHED it. I don't think it's a reflection of the machine, more the man. The MF seems to offer a lot, on paper. I did sit on the GC1715, but didn't get to run it, at all. I find the MF GC line to be a strange middle ground, even blend of the benefits the JD and BX compete over. To get a MF, with the same setup I got in the BX was going to cost around $2,000 more. If I could have actually used one, to try out, I think it would have been a very tough choice between it and the BX. No matter what you read, there's a lot of fanboys.
Great review, and thanks for taking the time and effort to post it! You are a fine example of what TBN is all about. Clearly, the OP cannot go wrong with either of these two tractors, but beware – the greatest angst you experience is right after your purchase, and the more similar that the two products are, the more dissonance! ("OMG, did I make the right choice?"). Goes with the territory, I'm afraid.
   / Trying to decide Kubota BX25 or 1025R #43
That is the most complete comparison I think I have ever read. What a happy ending.
Will we be getting picture of it?
   / Trying to decide Kubota BX25 or 1025R #44
Are the rpms to do work the same on both?
   / Trying to decide Kubota BX25 or 1025R #45
I believe the RPM's are very close, if not the same. I will have to check the JD manual to see. If I have some free time, later, I can look it up.
sixdogs, if you wanted pictures from me, I can provide a few:
The first commercial job I did, digging out portion of a sump pump line:
The large root I was able to break, with the backhoe:
Here's a few more shots, you can see how close the healthy tree is that provided the roots:
   / Trying to decide Kubota BX25 or 1025R #46
Here's the first time I put the 3pt kit on and the rear blade:
Needed fuel, so I drove 1.8 miles to the station while playing in the snow:
When I got done, I think it had around 12 hours on it( total, not just from this)!
   / Trying to decide Kubota BX25 or 1025R #47
Yes, both are "rated" at 3,200 RPM. Both will go a little higher. The BX needs around 3,050 RPM to run the mower deck, but I just throw it to around 3,000 or 3,200ish, if I need a little more juice (I've cut grass over three feet tall with it, a couple of times).
At the 3,050, the mid-PTO is at 2,500 RPM, I believe the BX has the highest rated mid-PTO, among the sub-compacts. This doesn't mean much, except, it (theoretically) should wear out parts faster. From what I've heard, you can expect problems around 2,000-3,000 hours, or dozens of hours after you stop maintaining it.
   / Trying to decide Kubota BX25 or 1025R #48
Here's a concrete slab porch I helped rip out:
Money Shot!! If you notice, the bucket is off the ground, it was on the ground, but the slab was so heavy, the outrigger pads kept sinking deeper:
   / Trying to decide Kubota BX25 or 1025R #49
Day 1 of digging a drainage solution. You can see I got started just in time. If I had started later, all this water would be in her basement:
Closer to done:
Where the dirt is going:
She wanted the dirt to go in the back, to make a ramp, to the back door. A stone wall will be made to hold the dirt and it will be covered in the same gravel the front pit will be filled with. She is tight on money, so the pit is just sitting there, until she has the funds for the next step.
   / Trying to decide Kubota BX25 or 1025R #50
Here's one reason I love this BX tractor: You can drive it all over, with a load, and not tear up grass.
The customer had the rock hauled in and I moved it around the house.
As you can see, the entire back and sides of his lawn have a pretty steep grade. I never spun a tire or tore up any grass:
This was the main area I drove, to get the rock to the east and south sides of the house. I kept the backhoe on, for ballast, and was glad I had it on. When we started, in the morning, the grass had dew on it, which made me nervous. The customer said he didn't care and would like to do it then. Turned out fine, no damage:
Where the pile was. I didn't get a before picture:
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
TANK MANIFOLD (A58214)
New/Unused Two Post Car Lift 10,000lb (A57453)
New/Unused Two...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
