ttr 4400 HST - moves great to backward but moves weak to forward ? some problem here
   / ttr 4400 HST - moves great to backward but moves weak to forward ? some problem here #1
joaorodrigues88
viseu
antonio carraro tt4 4400 hst
hello, I'm a new owner of a 2007 antonio carraro ttr 4400 hst, this week testing the machine I observed that the tractor don't have the same power and speed when it's move to front compare when I press the pedal to rear. I have a great speed and horse power when vehicle moves backward and poor power and speed when moves forward! testing on a climb, the tractor was struggling, and had no strength to climb, I accelerated but it's like as if the clutch was slipping, testing the same climb move backward, it climb it with no problems... Why this happens? I thought it might be the clutch, but it works well in reverse gear... If someone with experience in hydrostatic transmition can help me?
I'm already search on this forum for a similar problem and looking for the service manual on the internet, with no success...
Regards
John
   / ttr 4400 HST - moves great to backward but moves weak to forward ? some problem here #2
G'day Mate and welcome to TBN from Downunder./G'day Mate e bem-vindo ao TBN da Austrália.
A question first... it sounds as though the forward and reverse pedal is a single 'rocker' type, yes? (as opposed to individual forward and reverse pedals)
Seeing as your hydraulics work perfectly well in reverse (which means that all of your hydraulics works) the first thing that I would look at is the linkage from the forward 'half' of your pedal to the transmission (or wherever it goes). Something is loose and the movement of the pedal (in that direction) isn't happening.
Enjoy the site./Aproveite o site.
   / ttr 4400 HST - moves great to backward but moves weak to forward ? some problem here #3
Does the engine sound like it is working while driving forward?
Do you get different noises from the HST while driving forward Vs in reverse?
I would expect this model to have relief valves for forward Vs reverse. If the forward relief is stuck partially open it will limit the drive power and cause excessive heat in the system.
Do you a service manual for this machine?
   / ttr 4400 HST - moves great to backward but moves weak to forward ? some problem here #4
Some HST tractors allow more pedal travel going forward. Meaning a faster speed.
Limited backwards pedal travel limits backwards speed by basically forcing you to NOT push the pedal all the way.
Have you ever driven a HST before. It's backwards from conventional wisdom in that when you run out of power, the first reaction is to push the pedal more, and thats the opposite of what you want to do. Try not pushing the pedal as far and see what the power is like
Hello Wagtail, thank you!
Yes, the pedal it's a rocker type.
I think it's important to say that all the fluids and filters were changed at the official shop. And all the hydraulics works great.
tomorrow I will check for some bad linkage, But seems that I have no access to this, because the axis of the pedal goes directly to the inside of the "box".
Hello Oldnslo
The motor runs normally, I test the forward in low and high rpm, and the engine works well, but I hear the transmission struggling.
I can't find the manual... Will be a great help because It's the first time I drive a hst and I have no ideia how it works, usually where I can find this relief valves?
Thank you
LD1
This tractor it's reversible, so I think there are no limit, Now I have an idea ! I will try to test this tractor with the reversible mode, so it will invert the hydraulics of the rocker pedal, and I will check if in reversible move it will moves great to forward ( backward in the normal mode) and poorly in backward.
I will try to make a movie tomorrow to show you guys !
thank you for your help
   / ttr 4400 HST - moves great to backward but moves weak to forward ? some problem here #8
Hello Oldnslo
Thank you
Since this tractor is reversible it should drive the same in both forward and reverse so I doubt it is your technique since it operates fine in reverse.
Relief valve location: With out a parts diagram it would be difficult to say. They are almost always located in the HST housing.
I think there are no technique in the pedal, it's just step the pedal, and accelerate in the handle accelerator.
I will try to drive in reversible mode to see if the problem with forward maintain or change, if it's a problem in the linkage of the pedal it will reverse the problem, right?
The "speed fix" device, seems not working on the tractor, I move it when the tractor is running and it don't block a constant speed... can it have any relation with the forward ?
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
Quick Attach Hyd. Compact Roller (A59814)
Quick Attach Hyd...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
KOMATSU PC490LC-11 EXCAVATOR (A60429)
KOMATSU PC490LC-11...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
