Gear Wear Update.
After replacing my differential gears last spring and accumulating over 100 hours to this day, I have done a tear down and inspection.
Here's my report.
The oil was as good as the day I put it in. I did disassemble the center housing and lapped it with 320 wet on the 2 surfaces of the center case housing and the pump and motor housings.
My new gears installed last spring were the newer steel gears and not the powdered gears. There was no deterioration or wear what so ever.
I have full power and speed and can spin the tires easily when loading down the tractor
My conclusion:
The original powdered gears had too much tolerance in them with respect to axle shafts in and out play. A total of 80 thou when it should be about 20 thou total. I believe this caused the rapid breakdown of this style of gear. Once this break down starts it contaminates the oil with super fine particles, these particle are smaller in micron value verses what the filter could filter, thus causing the scoring of the pump and motor surfaces.
See:
http://www.tractorbynet.com/forums/parts-repairs/164892-tufftorq-k46-repair-guide-pictures-53.html Username P901
Pictures of powdered gears here:
http://www.tractorbynet.com/forums/parts-repairs/164892-tufftorq-k46-repair-guide-pictures-59.html
Steel Gears here:
As I did not shim my spider gears as Username P901 did and I do not have any gear wear I can conclude it may not be necessary if using the new steel gears. The choice is yours.
As mentioned in a previous post a build up of grass on top of the trans-axle can also stop the cooling of the fan and thus heating the oil to a breakdown temperature.
My recommendations:
1.) Make sure you have the new steel spider gears and if you don't, then get them.
2.)Keep top of trans-axle clean so the cooling fan can do what it was designed to do.
3.) Make sure you change the main oil filter...
a clogged filter will cause an oil starvation to the pump....
4.) Give surfaces a lap with minimal 320 wet, it takes no time at all. I used a piece of a broken mirror and wrapped my paper on it for my totally flat surface.
Regards
Don
