Turf tires and disc harrow
   / Turf tires and disc harrow
EA's disc spacing is 7.5" on all their disc harrows, as are LandPride in this size.
I do like their construction from what I can see in pics and videos, and owner reviews seem quite good.
Is there a recommended well-built disc manufacturer for this size tractor with wider 9" spacing?
   / Turf tires and disc harrow #12
Thanks I had looked at Tufline, but not Dirt dog. Nearest Tufline dealer is 3.5 hours away unfortunately.
Dirt Dog does have a dealer not all too far away from me.
I see on some of these to get into the 9" spacing with 20" discs, you have to size up to 72" or over.
Would that be pushing it for my 43hp tractor with turf tires?
http://www.dirtdogmfg.com/UserFiles/Image/200-series-specs.JPG
   / Turf tires and disc harrow #14
Have you measured the outside-to-outside width of your rear turf tires with a tape measure?
I speculate that measurement is about 70". You want a Disc to cover your rear tire tracks.
On some of these to get into the 9" spacing with 20" discs, you have to size up to 72" or over.
As you decrease aggressiveness of gang angle adjustment, draft force resistance decreases as well. So a minor operating width change will not stall out your tractor/Disc Harrow combination.
If you enter your LOCATION into your T-B-N PROFILE it will make answering some questions easier.
   / Turf tires and disc harrow #15
Half my implements are EA brand. The EA Disc Harrows are an evolution with improvements of the well proven, now defunct, Leinbach brand. I like easily adjustable Disc Harrows. Many respondents here never adjust their Disc Harrows; a shame.
If buying another brand for 9" pan spacing is considerable trouble, go with EA. Their customer service and delivery agents have always been good.
We are working dirt. Even I can outsmart dirt.
When soil has a lot of 3" to 5" stones the difference between a 7" and 9" "gate" can make a difference in dirt flow. We work sand.
   / Turf tires and disc harrow #16
ha ve you considered a tiller instead of disks? I do the same things you are talking about on my hunting property and i have disks and tillers. I have found the tiller to be much easier to get a good seedbed for food plots the disks have there place but as others have said. they need to be heavy. Whatever you get it is important to kill and mow any grass and weedsdown as low as possible before you try either implement. I have turf tires on one tractor and they work fine as long as its not muddy.
XCMG CV83PD (A53317)
Pickup Truck (A59230)
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Nissan Pathfinder SUV (A56859)
2014 Nissan...
SUV (A59231)
SUV (A59231)
