Turning trees in a valley into firewood
   / Turning trees in a valley into firewood #11
grnspot110: That is a kool log arch, I guess you made it, neatest I've seen.
   / Turning trees in a valley into firewood #12
Since I have rather limited resources, this it how I transport and process the logs into firewood.
  • First I get the tree on the ground, limb it up and pile the limbs on burn piles which are burned in the winter months
    Second I get the logs into manageable sizes for my Yanmar 169D tractor.
    To insure steering, i put 200 pounds of weight on the front for ballast and watch my load.
    There are 2 ways to move the logs, i can lift them with my forks or I can wrap a chain around the log and drag it with my forks.
    When I get all my logs in one spot I cut them all into rounds (cut 6 cord with my grandpa in 4 hours) and make a pile of rounds ready to split.
    I purchased a log splitter this fall (highly recommended for massive quantities of wood) and split the wood to specification requested
    I stack the wood on pallets (cut a square chunk from the center of a large round to tie the ends together) and stack 4 feet high (roughly the size of a pallet of wood pellets)
    After all this I put a tarp over all my pallets of split wood (to heavy for my tractor to move, will use a skid steer in the spring months) and I let the wood season.
    When I move the wood, I will purchase some shrink wrap material and wrap the wood together for transportation across the rough terrain here.
Now everyone does it different, this is just the way i do it with only a 19hp Yanmar, 3 point forks, a chain, my log splitter, and my chain saw. Relatively small amount of equipment for this task but that's all it takes.
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
