tv antenna
   / tv antenna #161
Weather and terrain has a lot to do with it. I知 running dual 4228 antennas stacked on a 50foot tower and pull 80 miles regularly but you need to consider your antenna height and elevation , the desired transmitter elevation and power, and obstacles in between. On good days I can pull stations 120 miles away. After the digital conversion some transmitters went to directional antennas that are now pointing the wrong way for me to get reliably.
If you keep your runs short and set it up right ganging antennas makes a huge improvement on signal strength.
I'd like to know more about ganging antennas. Previously I had the biggest antenna Winegard made. The last time it blew away Winegard and a couple others talked me into a smaller antenna. It didn't get as many channels as the big Winegard got with half the aerials blown off.
I haven't had a chance to go through this thread. Is there a high quality rotor to be bought anymore?
ganging antennas - Google Search
   / tv antenna #162
With service going out at 20*, I'd say you have water in something that's freezing and expanding, causing either a short or open circuit.
Most likely in the coax cable.
Cold solder joint!
Back when we maintained avionics the freezer was our best friend. (we froze the unit and when bringing heat close to the cold solder joint the circuit would re activate)
   / tv antenna #163
Cold solder joint!
Yep, that's a very good possibility.
   / tv antenna #165
Yes, any of the bell shaped rotors are excellent. In the used market, they were CDE or CDR branded. Now they come under the Hygain name.
You will need to go to the Amateur radio related sites to find them though.
Unfortunately Hy-Gain is run by MFJ now.
Hy-Gain
Several of the Yaesu rotors aren't bad also.
This G450 will handle up to 10 sq ft. of wind load.
GigaParts.com
At a typical hamfest a used Ham III or Ham IV would run you about $250 to $300 bucks. If you could find an AR40 or one of the smaller ones, they would likely be quite a bit less. The thing is the price of rotors has gone up a bunch in the last few years. The used ones many years old sell for about what they cost new back then. Of course all of the CDE rotors are rebuild-able. These rotors were originally designed to turn medium to large ham arrays, and have braking mechanisms and ball bearing races in them. But if you are talking about stacking large TV arrays, the wind load can add up to quite a bit, and you should consider these rotors. All of the smaller "tv" rotors have no brakes, and some even have nylon gearing. They ain't gonna last long.
Norms rotor service rebuilds rotors, but also has rotors for sale. (refurbs)
An old Ham II or Ham III would be fine for the largest of TV stacked arrays. Even an old HAM-M
Norm's Rotor Service - Sales, Service and parts for Ham Radio antenna rotators; antenna rotor service; parts for antenna rotors
NRS - new and rebuilt rotors and control boxes for sale
If you need a lower mast bracket support I have a new one never used with my old Ham III
It has always been in a tower and never had need for the lower mast support bracket/clamp, hence it is new unused.
I would have to dig it out of a box up in the barn, but I would let you have it for less than Norm wants for one.
Give us a shout if you need more info.
   / tv antenna #166
I have almost given up on TV aerials. The claims are so outrageous and the results seem so pathetic.
IF, and it is a big IF, a 50 ft mast would bring in 3 main stream stations AND provide a good enough signal to get 4G cell service (that would allow the unlimited use of Netflix etc.) I would be all over it. I hate paying my satellite bill. And my internet capacity is so limited I cannot watch much.
   / tv antenna #167
There is no substitute for height.
Rohn 25G 10 foot sections often go around here for $25 $30 per section. Or they can be obtained from business's that will let you have them if you will take them down. Sure you have to have someone to climb them. Or build tilt over mechanism.
This is all bigtime ham radio techniques, but large TV arrays at low heights may still not be enough. There is no substitute for cubic inches or height. :)
   / tv antenna #168
Using a channel 7-51 antenna has two advantages . Much less wind loading without the long elements for channels 2-6. And less overloading the antenna input with noise/intermode from adjacent broadcast FM radio signal.
Lowering the noise floor is just as important as increasing signal strength.
   / tv antenna #169
I've got 5 of those sections and 1 top section sitting in my back yard.
   / tv antenna #170
I put Rohn into Searchtempest. The only one in a 500 mile radius is a heavier model that was used for a wind generator. $2,600 for three 20 ft sections with the first two over 500 lbs each. Transporting that 400 miles and erecting it would cost far more than I want to pay! Then it would a gamble whether it would see anything, since the ridge I can't see over, shows zero reception on the ridgetop. Oh well.
Craigslist: Tower /ROHN Steel Heavy Duty free standing 50 feet-tall - electronics - by owner - sale
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
Manac Walking Floor Trailer (A50322)
Manac Walking...
JOHN DEERE TS LOT IDENTIFIER 138 (A53084)
JOHN DEERE TS LOT...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
