California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 14,998
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I wish that would work here. I've never seen any hint of a signal from the couple dozen stations in the San Francisco area. I've been trying ever since the digital conversion, using the 4228, another claimed high gain directional antenna, as well as the old antenna that worked before the digital conversion.Weather and terrain has a lot to do with it. I'm running dual 4228 antennas stacked on a 50foot tower and pull 80 miles regularly but you need to consider your antenna height and elevation , the desired transmitter elevation and power, and obstacles in between. On good days I can pull stations 120 miles away.
If you keep your runs short and set it up right ganging antennas makes a huge improvement on signal strength.
I think what I have learned is that my location with a hill on the horizon slightly higher than my location, will never get reception of the frequencies now in use. I could try a 50 ft mast. That sounds expensive for something that might not help.
I posted this photo here in 2006 (to illustrate carrying hand tools). It shows the horizon I need to see over, to get signal from the SE, the Walnut Grove tower over in California's Central Valley.
https://www.tractorbynet.com/forums...el-carrier-golf-bag-p1030489rgolftractor2-jpg
And here's my horizon to the south toward San Francisco. My line of sight to San Francisco runs through the left edge of the tall Eucalyptus trees. There are other less interesting stations a few degrees to the left of that, which shouldn't be blocked by those trees.
https://www.tractorbynet.com/forums...le-nursery-stock-p40375r-orchardseptember-jpg
