DrewL
my bad............I meant winner. My point is, plenty of honest disscussion with no conclusion I can see. I'm going to use the additive though
DrewL said:my bad............I meant winner. My point is, plenty of honest disscussion with no conclusion I can see. I'm going to use the additive though
rback33 said:Makes two of us....![]()
DieselPower said:Ditto, I'll third that.
In fact I even use additive in my furnace fuel oil. Got a new furnace installed last year and it is still under a service contract. Guy came out about 2 month's ago to do the winter furnace cleaning and adjustment and was amazed how clean the fuel nozzle and fire box were. Said it was the cleanest he as ever seen and that he has been a furnace tech for almost 20 years. So it works in my furnace to and will continue to use it.
KICK said:never will reach a verifiable conclusion in reference to any of the
"MECHANIC IN A CAN" products.
you cant believe the offending companies lab test claims .
remember when slick 50 was heavily advertsing their product.?
they would run slick 50 in a briggs and stratton engine and then drain it and show how it would run for half and hour with no oil.
Briggs and stratton got curious about slick50 using their product in an advertisement without their permission. so they ran an engine with slick50 and one without, drained em and tested em. both engines
ran half an hour.
Briggs sued slick 50 before the FTC and won.
cowpie1 said:After going over all the posts here, I have noticed no mention on Howe's fuel treatment. I have used it for over 20 years with excellent results. I hardly have any water in the separator and have experienced long life fuel pumps and injectors.
If any of you were to stop by most of the major truck stops, you will find that Howe's is the product they carry the most of. It has been a transportation industry standard for decades.
To compare, if you take the bottle that Howe's comes in and fill it with FPPF or PS, it will eat thru the bottle. The products other than howes has solvents in it's contents. Howe's has no solvents or alchohol. I have had injectors last over 700K miles on the semis I have operated. It is the ONLY product that we used in Alaska for the 6 years I lived up there year round.
Cost is comparable to PS and others. I realize that Walmart carries PS and not Howe's, but that may speak volumes. I realize that this all sounds like a paid ad, but it is my experience of over 20 years.
Is PS a bad product, no. Same with most of the other additives. But if you want a product that has proven itself far longer with those whose living is dependent on it, go with Howe's.
DieselPower said:That's true. But Howe's is not the only one like this. TRC's is the same way and will not "disolve" a bottle.
As far as Power Service goes, this is quoted directly from their website.
" 2. Do Power Service diesel additives contain alcohol?
The only product manufactured by Power Service that contains the type of non-harmful alcohols recommended by engine manufacturers for removal of water is Power Service Diesel 911. Diesel 911, as its name implies, is used to solve the fuel emergencies diesel engine operators most commonly encounter. In winter, Diesel 911 reliquefies gelled fuel and de-ices frozen fuel-filters in a matter of minutes, eliminating the need for a tow truck. Diesel 911 also removes water from the fuel system to prevent icing problems and extend the life of fuel-filters, fuel injection pumps and fuel injectors.
No other Power Service product contains any alcohols of any kind, including Power Service Diesel Fuel Supplement +Cetane Boost and Diesel Kleen +Cetane Boost. "
