Loader Un-findable Part Need your help
   / Un-findable Part Need your help #21
Pretty sure that's already occupied by the injection pump.
//greg//
I mean on the front side of the engine, like the other front mounted pump. I'll take another look at mine.
   / Un-findable Part Need your help #22
There isn't another accessory take-off on the left side front, so you are limited to two on the right side. I assume this would be the same on all TY x90 engines.
   / Un-findable Part Need your help #23
Well it looks like I have same Hercules 2224 tractor with the unusual twin pump setup. I need to remove/replace the steering pump driver. I was wondering how you went about removing the gear assembly so as I can get to the pump driver. The gears look OK. Any information would be greatly appreciated.
   / Un-findable Part Need your help #24
Why not consider a belt driven pump or even driving a pump off of the crankshaft via a universal joint?
On my little tractor I U-joint drive a second pump for greater GPM's for my FEL. I made an adapter that bolts to the C/S fanbelt pulley.
Have been running that setup for 10 years w/o any problems.
   / Un-findable Part Need your help #25
Piloon my Kubota uses a front crankshaft driven pump for the front end loader. It has the hyd. tank mounted on the right side loader up right. Unit is 35 years old, but have been able to keep it running.
   / Un-findable Part Need your help #26
My old 1959 MF65 had a crankshaft driven pump (front of engine) on the front of the tractor for the FEL too. I was still able to get the parts when I managed to break the drive coupling disc. Straight forward set up and easy to install/replace
   / Un-findable Part Need your help #27
thanks for the input. Am looking to see if anybody has a picture of how to convert to a one pump or series of pumps on the TY290 engine as advised by other posts.
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
Electric Golf Cart (A56859)
Electric Golf Cart...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
