Unbelieveable - small rant on snowblower
   / Unbelieveable - small rant on snowblower #41
You still have both boxes? Enough parts from both to make one good one then?
Doesn't resolve your issues, but a cheaper fix for the blower if you've got the time. Perhaps sell and buy another.
   / Unbelieveable - small rant on snowblower #42
Interesting -- just judging from your pics - last year gearbox was looks like a defective or weak metal shaft. this year gearbox has casing failure and looks cheap. your shaft looks pretty good but too shiny.:rolleyes: . Anyway is it possible that your blower is on cockeyed ? or one of your 3 pt lift arms have too much movement ? Was the chainstay on tight ? I wonder if there was a angle issue here, nothing wrong with your equipment instead? Sorry for these questions - we are just simply not there to see the whole thing.
Exactly what I was thinking. I'm no metallurgist, but I thought both the shaft and case looked cheezy.
The blower was level, I actually put a level on it and adjust the side links until level. And there's really no play in them. The drawbars are tight enough too, maybe an 3/4 - 1" movement to either side. Just for some give.
I don't know squat about building gearboxes but yes, I'm going to try to rebuild to have a, god forbid, spare. I was unsure of the first one until last night because I didn't want to move 2 tons of wood stove pellets to get to it. Forgot it was on that particular shelf when I stacked the pellets :rolleyes:
I'm actually off to the hardware store to get a narrow wall 13mm socket to crack the gearboxes open. There's 4 nuts on the boxes that are impossible to get to w/ a wrench or standard socket. Grrr...
Wish me luck
   / Unbelieveable - small rant on snowblower #44
Looks like a key in the input shaft. Can I assume that the shear pin is on the other end of the drive shaft ?
638 & Kubotafan you're right. It is a keyed shaft w/ a shear bolt on the tractor end. Wicked PITA setup.
Had time to split open the gearbox last night and *&^(%! the same thing happened as last year's! The keyed shaft that the PTO attaches to and drives the fan DIRECTLY broke. So I can't even rebuild last year's gearbox.
I called for replacement parts and replacing the shaft would be about half the cost of a new gearbox. But it would also be 4-6 wks to get a new shaft! That I obviously can not do.
One other little tid-bit, and I'm not really inferring anything here, but I found it interesting that my Comer (Italian) designed gearbox has a big ole MADE IN CHINA stamp on it.
Guess I suck it up and hope it lasts this year. But I have that sinking feeling...
For sale: 60" snowblower w/ low hours and new gearbox :)
   / Unbelieveable - small rant on snowblower #46
You could get a local machine shop to make you up a high quality shaft. Not sure of the cost, probably 100-250$
A gentleman at Comer's US office was nice enough to email me. He informed me that neither the US or Italy office was able to find a spec sheet on this particular gearbox. But he did inform me that since it is a 1:1 ratio that it is definitely rated for 15HP @ 540 rpm. So to end this long saga basically my dealer hosed me by recommending this blower for my tractor. I'm set up to fail again. Grrr...
   / Unbelieveable - small rant on snowblower #48
Reading thru this, I would look into the fan being correctly balanced....I know some of the cheaper (**cough**Meteor**cough**) blowers dont balance their fans and similar things have been reported....the excessive vibrations caused by the improperly or NON balanced fan will literally shake & break things apart.
I thought of that Dave so I did check it. And yes, it was not balanced. It wasn't too bad, but I did add some small tire weights and balanced it. My buddy owns a repair shop and we rigged up a jig to hold it on his wheel balancer, worked pretty slick actually.
   / Unbelieveable - small rant on snowblower #50
I dunno what to tell you then....If I were in your shoes I'd ditch the meteor and shop for a Blizzard or Pronovost.....
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
2020 JOHN DEERE 444L WHEEL LOADER (A52709)
2020 JOHN DEERE...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
2003 Big Tex 10PI...
